Suspension Rebuilt!
Suspension Rebuilt!
ok I got my front suspension rebuilt.. new outer tie rods, new upper control arms and new lower ball joints, and daizen sway bar bushings (OE) for front and rear - (i already have TEIN CS, and Cusco STB)
before I had this "clunking" sound when I would go up drive-way's and such and other bumps in the road. I had everything installed for $380 (the job took about 9 hours)
from what I can tell right now, the weird "clunking" sounds went away, and the steering feels smoother.. I'm gettin' an alignment tomorrow morning so I'll do another write-up after the alignment
I also have the Daizen Control Arm Bushing Kit but I opted not to have them installed because I already got new bushings (OEM) and all my other bushings are in good shape.. plus I don't know how stiff the ride will get and I don't want to lose the luxurious feel.
yes, the control arm bushing kit stiffens up the front end, I just don't know how stiff it feels and don't know if I want to do it yet because I already have new bushings and the lower control arm bushings are in good shape.
I just recently had the Daizen bushings installed. It doesn tighten the ride up but not so much where you would not be comfortable. I'm running on L-Tuned suspension and OEM 17" wheels. I think the ride actually got better. No more wandering, clunking.
The steering response is much more crisp than before.
I think this was one of th best mods I've performed on the car to date
I've replaced my control arms October '05 , spent over 1K for OEM parts and two weeks ago decided to replace them with Daizen kit, all i can say: there is big a** improvement over stock. I don't have to fight with seering wheel anymore left to right and vice versa. I think replacing castor arm bushing with Daizen might change ride quality a lil bit ( more harsh) due to Big piece solid rubber Daizen is made . I'm convinced that combination of Daizen upper control and lower control arm bushings with brand new OEM castor arm will do good job for you. I know it is sad taking brand new arms apart but thats what i did and i do NOT regreat at all.
After all, thats only me - you might feel different
Just an idea
Just an idea
I'm looking at doing the Daizen upgrade. I am in Dallas and the shops that will do this work want an hour of labor for each pair of bushings. Basically they have told me it is an all day job. $600-800 seems really high to me. Feedback.
Even If I had to pay 500 or 600 bucks I would. The mod is worth every penny.
ok i just got the alignment done... everything is MUCH better... steering is firmer, clunking is gone, feels a bit stiffer but that's only 'cause i got new parts.. i'm gonna do the daizen bushings a little later after the newer ones get kind of worn down.. and i feel a lot safer in the car, just the peace of mind that i know i had everything fixed.
Northern California Regional Officer
The stiffness is a mechancial description of what the bushings do. That shouldn't be confused with saying the "ride" is stiffer. If you have upgraded sways, lower profile tires and coilovers, those mods all add more ride stiffness than the bushings can by themselves.
There is a better steering feel and tightness. If you have a lot of the TOM's chassis braces the Daizen control arm bushings "will" add more stifness to the ride, but anyone with all the TOMs braces and STB's I consider already has a stiff ride, so adding the Dazens should not be objectionable to those folk.
You already paid how much for the upper a-arms, plus labor?
It has already been talked that the bushing labor and the Daizen bushings add up to about the same cost as buying new OEM a-arms with labor.
Could of saved some money not buying the a-arms. It doesn't make sense if you are considering taking them back out to install the Daizen bushings.
Well you have cheap hook up for labor , so for you , you might be able to get away with it.
hmm.. so i should or shouldn't put in the daizen bushings, RMMGS4?
you're saying the steering will feel stiffer but not the ride quality? but i've read other people that had these installed and they said the ride actually got stiffer and some of the road harshness was transferred into the cabin..? iono maybe i'm mis-reading lol
If low profile tires and stiffer sways don't bother you, it's a guess that bushings won't bother you.
Out of most suspension mods availble for the GS, the bushings are pretty low on the list for adding stiffness to the ride.
Those who commented on feeling stiffer, how much stiffer? Yes , it can transfer to the cabin, just like every other suspension mod. Everyone has a different definition and it depends on what other mods you have that will add up to more cabin transfer. We can only get so far with this discussion.
Just like every other mod, only you can decide what is right for you. I guess you'll have to ride in someones car with bushings to find out before installing.
hmm i don't have new sways, just sway bushings... with the TEIN's, they feel like stock almost i guess i might just put them in since i bought them anyways haha thanks RMM
Ahheck01
Suspension and Brakes
01-12-15 06:27 PM
