Replacing brake pads
It's time to replace my rear brake pads. I have 60k and I think the pads in the rear are original.
Have anyone purchased brake pads kit from Sewell? I see that they have what's called pad kit set vs. just pads. Are they the same thing?
Does anyone know Toyota Part # for GS400 rear pads?
I was wondering if I also need Brakes-Shim Kit Anti Squeal.
You should be able to reuse the shims and the main spring as long as you clean them and they aren't deformed or bent. As far as the Toyota part# can't help you out, I replaced mine with aftermarket pads.
