How to get 1" more HEIGHT in rear...
I've had my Eiback springs for well over a year now, maybe closer to two and the rear has always sat a little lower than the front. This is especially annoying since I have yet to put in my subwoofer setup which would just make it worse.
Is there anything like a formed rubber pad or something that would give a proper seat for the coil and raise the car about an inch or so?
I thought you could put rubber around the coil to raise it but i may be wrong? You may need a different sping with a different spring rate especially if you have a system.. Good Luck and keep us posted...
jtgs400
02-22-11 04:37 PM
