what is a pillowball mount?
I recently purchased the Tein SS coilovers and it says pillowball mounts arent included. What is that? I did a brief search but could not find what it is. thanks.
Note: Most pillowball mounts come as solid metal piece, usually do not have rubber cushion like OEM does. In your case you have to reuse your OEM upper strut mounts on your SS Teins.
Well, it all depends what kind of ride are you looking for. Pillowball mount will give you better steering reponse but you'll have to sacrify ride quality, solid mounts transfer much more road noise on steering wheel also make suspention noisier a lil bit. OEM mounts are more comfortable but with Tein SS diffrence betwen both is bearly noticable. In every day driving it wont matter unless you'll track alot. Save money and reuse OEM mounts.
Originally Posted by LEXSOOS
yes i do have few, why?
They are about 30 pounds each+tire. Bought them 9 months ago for 1800 shipped, could not afford for quality wheels at that time but i don't regret purchase i've made. Here is my old picture from last year, no spacers on:
Pillowball mounts are unnecessary on a street car.
"Pillowball uppermounts" are upper mounts with a spherical bearing pressed or assembled inside.
Pillowball uppermounts are completely solid and will transmit more noise and vibration to and through the chassis. They have very little performance benefit on a street car using standard tires.
OE upper mounts use a rubber bushing that have slightly more compliance and are designed to absorb noise and vibrations transmitted through the suspension.
When adjustable coilover suspensions started becoming more affordable and popular, pillowball uppermounts started to become associated with "performance" since many pillowball uppermounts had camber adjustment options. It's a big misconception many people have about adjustable coilovers, and can make a normally streetable suspension unusable with all of the additional noises and vibrations.
Many strut tower openings are not large enough to allow for a camber adjustment plate, so many times if you get pillowball uppermounts with your suspension, you wind up adding a solid piece to your suspension that has little to no realistic benefit when it comes suspension performance or tuning on a street car.
Unless you are running an aggressive suspension and are racing with extremely grippy tires on a racetrack...I personally wouldn't recommend it.
Originally Posted by bazop
I don't mean to hijack the thread, but LEXSOOS, why do you give the thumbs-down to the TM's?
I actually have had them for about a year now- I can't tell a difference better or worse. I was just surprised because everybody else seems to rave about them.
Scott1258
Suspension and Brakes
08-10-07 06:20 AM
