help!
enclosed is a picture of a bolt that i found loose. it is part of the rear suspension where bolted to the car. I have labeled it 1. Question, can I just tighten this bolt and everything be good again, or should I have this professionally looked at? I have also labeled another spot of concern. Point 2 looks is a rubber washer that is clearly exposed. Is this how it is supposed to look like?
Screw the bolt tight. Make sure you dont let the rod spin when screwing the bolt. I think this one requires an allen wrench on top to keep it in place while turning the bolt tight.
The rubber piece is ok.
clynnh1230
Suspension and Brakes
14
05-01-22 02:02 PM
