98 GS300 Brake Question
The vehicle has 77K. Each time the brake pedal is pushed or when the car starts, there's seems to be a brake pump sound coming on but have checked fluid and everything is fine.Also the ABS light seems to stay on for about 30 secs when you start the vehicle up.
Is this normal?
Oh yea also just recently changed pads and rotors also
Is this normal?
When you changed the pads and rotors did you bleed the brakes?
Only time the pump would go on was after I just changed my pads and started to bleed the system.
You may have air in your line so you might want to try and bleed the brakes and see if that helps.
