Fender roll or coilovers?
Old 06-13-06, 01:13 PM
lfrers
lfrers's Avatar
Default .
Anyone got pics. I seen Emerald's. Lets see some do it yourself fenders that have been rolled.
Old 06-13-06, 02:11 PM
Sc400on20s
Sc400on20s's Avatar
What is you're offset?? If it rubs badly it must be a low offset (+15 or something)
The thing I don't get is that your wheel is a 18x10.5? Your tire should be streched a little more than that if you're on 275's...Unless your running something bigger than a 275? Than that would be your problem.
If all else fails...get some correctly fitted shoes, I'm sure you can sell those HRE's for a pretty penny.
Old 06-13-06, 02:22 PM
lfrers
lfrers's Avatar
Default .
I wanna keep 'em. I like the way they look and I havent seen any SC300s with the same wheels ( that I can think of )
I like the look of Emerald's rear fenders and was hoping to do somthing similar.
I looked at them yesterday and just cant see how you can do it with a bat or other simple hand tool. The car is nice and I dont want to F it up. Knowing me someone will explain it, I will try it , and then go look for a bodyshop to fix it. $$$
Clueless as to offset. The wheels were on the car and the recipt does not say.
Old 06-13-06, 03:38 PM
Sc400on20s
Sc400on20s's Avatar
Are you running 295's??
Old 06-13-06, 03:55 PM
lfrers
lfrers's Avatar
Default .
I'll look when I get home.
This is the only shot I have of the rear tires from a straight back angle.
Old 06-13-06, 04:36 PM
Sc400on20s
Sc400on20s's Avatar
From the sidewall buldge, looks like you're either running 295's or 275's on a 9.5" or 10" wheel.
Just a guess though...LOL either way looks good!
Old 06-13-06, 05:12 PM
SC400DAVE
SC400DAVE's Avatar
Looks awesome! I really like your exhaust set up. Looks like the "tips" are tucked in. Nice. What kind of set up do you have?
Thanks
Old 06-13-06, 08:43 PM
lfrers
lfrers's Avatar
Default tire size
they are 295/35/18 18x10.5 rears 18x8 front
I think I am going to get coilovers after I do the fender roll because as it turns out all of my tires rub. Except the right front. Go figure.
Old 06-13-06, 08:44 PM
lfrers
lfrers's Avatar
Default exhaust
Thanks
Exhaust is all Greddy. No cat.
I just Thermoshield fiberglass wrap on the hot side of the trubo and the downpipe and the stuff is smoking. Smokes kind of a lot I think.
Is that normal? If you put Thermoshieling on do you have to use the silicone spray??? Anyone?
Old 06-13-06, 10:49 PM
roo
roo's Avatar
roll for clearance and pull for the win!
Old 06-14-06, 11:46 AM
Sc400on20s
Sc400on20s's Avatar
295's...I don't think rolling is going to solve your problem...by the look of your wheels and the lip you have in the rear, you have a pretty low offset and trying to stuff 295's in the well is pretty hard. I would live with the rubbing until you need to by a new set of tires (275's or 265's)
Good Luck! and post 1/4 mile numbers when you get a chance.
Old 06-15-06, 10:21 AM
lfrers
lfrers's Avatar
Default Yea...
I realize now that the SC I crashed had the fenders pulled & rolled.
Your fenders look good bro.
I dont know if I want to get into all the bodywork. I may just get a tire smaller than 295 and roll the fenders. For now it's driveable with just me in it.
I have a vidio of the car pulling on the Dyno from Yesterday. I will try to post a link.
Now if I can only figure out how can I post a video?
Old 06-15-06, 12:36 PM
lfrers
lfrers's Avatar
Default Dyno Video
Just had the car Dyno'd.
Respectable power but not crazy.
Check it out
http://video.google.com/videoplay?do...607&pr=goog-sl
Steve at SR Motorcars had to put some wheels off a Skyline on the SC to do the pull because my wheels rubbed bad when the car would squat down.
Old 06-16-06, 08:41 AM
One HoT
One HoT's Avatar
http://www.team-integra.net/sections...?ArticleID=698
Above is an article with pictures utilizing the baseball bat method..
The baseball bat method will probably work for the front fenders but ineffective for the rear. Both rear fenders have thick metal that doesn't seem to bend or flex. You might want to consider cutting the fender with a dremel or a cutting tool of some sort. Or just rent a fender roller or go to someone who has one; that way it comes out clean.
Old 06-16-06, 11:35 AM
lfrers
lfrers's Avatar
Default .
Thanks for the info bro. Yea, i just realized I have to roll the front too. Good info.
Quick Reply: Fender roll or coilovers?
