trac light
trac light
Hey guys,
Just replaced my front rotors and pads, and the trac light that is on the rpm meter is on now. and also the check enegine and trac off keeps turning on and off all the time. Before, the check engine and trac off would come on like once every 6months or so, and stay on for like 10 mins, then go away for another 6 months. Does anybody know what could have triggered this? does it have anything to do with the rotors? thanks!
When you get the cel, which is an emissions issue that is realatively easy to fix, it shuts down the trac (and turns on the TRAC lite) and shuts off the Traction control. As for the other times, I have the same problem and haven't found the fix yet.
Paul
Paul
check your brake fluid level. I had the same problem with mine and I topped up the brake fluid and the trc light went off. The traction and the ABS are running off the same system.
QLex300 (12-28-21)
drummer195
05-29-18 01:14 PM
uMulla
09-10-12 05:03 AM
shajbot
07-16-11 06:30 PM
