Need help deciding
Need help deciding
I'm looking for a shock/spring combo for my SC this time around. It definately needs the drop (one of the rear struts is bad as well). The front has about a 3 inch gap from the tire to the fender, and about 2 inches in the rear. Here's a pic of the car.
I don't want to drop it TOO low but not sure exactly what combinations bring what amount of a drop and how much I actually need. If it helps any i'm running 275/35/18 +45 (should've gone with 19's. 18's still look small with a kit on). Fenders will also be rolled. It barely clears the wiring harness on the drivers side fender lining by the washer reservoir. Lemme know what you think would be best. Im having trouble deciding.
