switch from L-Tuned to Tein CS
Hi, I've tried searching, but I get too much garbage. I am wondering if anyone has switched from L-Tuned setup to Tein CS, especially if it's the new Tein CS. I am now running on L-Tuned S/S, and I am not happy with the float. Don't want to go to Flex since it sounds like it will kill me on our crappy streets, but want something tighter than L-Tuned. So I guess my question is, where on the Tein CS adjustment range does L-Tuned S/S compare? soft? middle? hard?
Thanks!
-pavel.
Thanks!
-pavel.
i have the TEIN CS - and i LOVE them! i mean.. the drop on them is perfect.. the ride comfort is better than stock (IMO) i didn't have the L-Tuned set up though..if you can, you should try to ride with someone that has TEIN CS on their GS to compare, but if you do the switch, you won't be disappointed at all! good luck on your choice
Thanks!
-pavel.
Thanks!
-pavel.
if you want GOOD handling though,i would say you want flex at least. but that's too stiff for me already
The One
It has been so long I can't remember the details. I went from L-Tuned to Flex to CS (v1) so I did not have them back to back. For some reason, I actually think the CS (on the softest setting) is a bit softer than the L-Tuned . The CS is still more controlled than the L-Tuned, though.
I know there is a cost difference but I think the CS is just better than the L-Tuned in every way (handling, ride quality, lowering flexibility). From rominl's and RMMGS4's reviews, I can only imagine that the new CS continues this idea and possibly even improves on a good thing.
I have L-tuned and have driven vehicles with the TEIN CS. The L-tuned on my car now has no float what so ever. Especially compared to stock suspension setup. I am very pleased and decided not to go with TEiN CS even though they have more adjustability. I have taken my vehicle well into the triple digit speeds without floating like it did with stock. And taking corners are very secure and no dive, bobbing and weaving. TEIN CS are nice but for me not much of a gain imho. But someday I may get them anyway.
Well i just went from L Tuned to the NEW CS this weekend and what a diffrence. Before i couldnt even go over 100mph with out the car feeling unstable, this weekened with the new CS i was doing 120-140 on my way to palm springs no problem, almost as good as my 350Z
Everything in Moderation
Originally Posted by XBS1
Well i just went from L Tuned to the NEW CS this weekend and what a diffrence. Before i couldnt even go over 100mph with out the car feeling unstable, this weekened with the new CS i was doing 120-140 on my way to palm springs no problem, almost as good as my 350Z ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Full soft, go to photobucket.com and search "zpimpn" thats my GS, the most recent pictures are with the Teins the front is at the lowest setting and the rear is at the stock setting, need to lower it some more. The other pictures of the GS are with the L Tuned and front Tanabe Springs!
nate579, I agree that compared with the stock setup, L-Tuned is much better, but still the float is there. Maybe your highways are better than what we have here or something. When I go over a ridge in the road, the car goes way up, then way down, then up, then down. Like a boat on a wave. Float.
I do like the L-Tuned setup sometimes. Like in the city. That's why I want to know where in the range of Tein CS the L-Tuned compares.
Thanks!
-pavel
Thanks!
-pavel
-pavel.
i swtiched from l-tuned to teins a while back.. (the old CS) and i LOVED them. looked much better IMO and felt MUCH better. more solid handling, not bumpy at all (as far as lowering cars go, of coruse goin to be a little more bumpy but nto much at all) u will NOT regret dumpin the ltuned. but with suspension work its so hard to determine what "bumpy/stiff" is to one person to the next.
i dont recal what stifness i had my TEINS at.
hope that helps at all
Tony
Tony
you may look into keeping your springs and upgrading your shocks to bilstein sport. this will take away floaty sensation. I had this setup prior to coilovers. i wanted to have the capability of raising and lowering.
do a search on bilstein sports and you'll some good reading.
Well my Z hasnt been stock for so long i dont really remember what it felt like, but right now its not even close, my Z has almost zero body roll, feels like its on rails. I think When i am done with my suspension mods on the GS ( Tein CS, Daizen sways, Daizen bushings, and some under braces,) it should handle as well as a stock Z, with all the stiffest settings on the GS.
Hope this helps!
Hope this helps!
Those comparing old CS with L-Tuned, the comparison is not going to be the same as New-CS with L-Tuned. The new CS does not float even at the softest setting. It appears the springs are stiffer than the old CS (which is a good thing), Henry chime in here if you agree.
At the full hard setting the NEW CS will be closer to the Flex at the softer settings.
The Flex has the edge on hard core handling, but sacrifices it in noise and comfort. With my New CS, the only GS set up I would take over mine in handling would be one that had the Flex PLUS all the Toms Chassis braces, the Front & Rear STB's, adjustable sways, A- arm bushings and MOST IMPORTANT the SUPERIOR Grip of the Michelin PS2.
Tire grip accounts for a lot when we are talking handling / grip. There are probably only 2 other street tires that can handle close to the PS2. If people are running Pirelli, Conti, Kuhmo, or All season tires, then I would say it almost defeats the purpose to use the Flex without using a Premium dry grip tire. If you are hard core into handling and you don't utilize the best performance tires available, then why use the Flex, HA or otherwise?
I'm pretty happy with my set-up, for me is the best balance of handling and smooth ride. With my 25 series rear tires, I think people would be surprised how smooth my ride is with the CS.
