Installing Supra Brakes + Rotors.....Question?
![](https://www.clublexus.com/gallery/data/500/P9080072.jpg)
thats how i had them installed before i took them off my car and sold them to you.... apparently how azdesertgs said.... but hey if its working good for u the way it is juts keep it like that
You flipped them! Mine are like Adam2562's. That is the way that Rotora said to install them. Im sure they stop fine but they had to do some R&D for a reason ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Your calipers look great tho
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Your calipers look great tho![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
As for the paint...thanks
Originally Posted by milky
i didnt know the supra calipers clear the stock wheels??
yea it does need a 15mm spacer but i'm also looking for wheels... spacers arent a great idea every now n then mine will make a lil noise.. i get a lil freeplay... thats why lately i've been considering G35 rims like Jeff Tsai's maybe in chrome if i can.. or Supra TT wheels preferably in chrome or polished...
What did you use to sand the calipers down so smooothly? What grit or sander?
Heres how I got it to finished product.
-Get calipers from member here on forum used....arrives at door. Open and inspect everything.
-Take calipers apart. Everything....remove all seals, pistons, etc. Now the caliper is in 2 pieces.
-Back piece is made of aluminum while outer piece is made of cast iron. Back piece= easy to sand and prep while outer piece is some serious b1tch work. I spent at least 1hour with the dremel and sanding just on the outer piece PER caliper. Initial sanding needs to be done with as low grip as possible. Even 20-40grit is fine, as the cast iron will eat thru that sandpaper like nobodys business in a few minutes of sanding. Oh yea, if you have a sandblaster....this step can be done in about 2minutes. Note: I didn't have a sandblaster
-Work you way up to around 400 grit. Increasing from 20-40grit in 50-100grit increments.
-Once you have reaced 400grit level, dry everything off and prepare to paint calipers.
-Paint calipers with VHT brake caliper paint....spray bottle not the brush.
-Let it dry overnight then the next day bake it in the oven at 500F for 20mins. Remove from oven and set on heatsafe surface for it to cool down.
-Go back to the sink and sand down the paint so it's smooth. At this point use 600grit or higher. Whatever higher level is fine, just more work and time to sand it down.
-Now repeat the bolded steps at least 3times. I did mine about 6-7 times. The paint surface is FREAKIN SMOOTH!
Also, on my calipers I did a two-tone paint. Talk about time consuming! Had to mask everything off two separate times and bake it at separate intervals. I know something I won't be doing next time....lol.
Ok, so just to make sure. I need to flip the rotors around right? Right now they sit as it is in the 2nd and 3rd pix I posted. I need to make it like the 1st pic right? I just want to make sure 100% before I tear apart the brakes again.
brakes, curved, difference, gte, installing, instructions, make, prep, rotors, slots, slotted, small, supra, vane, vvti
