**My brakes squeek !**
My brakes squeek !...I didnt know til the other day ..I went to a Dodgers Game and as I was leaving the parking lot I had my windows and I hear brakes squeling ....at first I didnt think it was me but then after a bit of stop and go ..I realized it was... and its bugging me ....they only sqeek when when Im going slow and am applying preasure to the brakes ....
I have Axxis Deluxe Brakes pads (purchased at Carson)
and F & R slotted x-drilled Rotors ( purchased ar 88rotors)
what can I do to get this fixed
Remove and clean the front pads... Inspect the rotors for excessive grooving
Grease the pad backs and shims.... note attachment for example
I also grease the edges of the pads where they ride in the caliper, atop the stainless inserts.
(the shim alignment tabs point away from the disk, both inner and outer, when reinstalled)
Wipe any excess the may squeeze out the shim edge.
I've had my new brake setup (Rotoras w/ Akebono) on for over 3000 miles with no squeeks at all. I used the supplied shims and grease on the back of the pad that came with the Akebonos. But on all the spring clips that make contact with the caliper and the pin for the rears I used a small amount of anti-seize. Someone gave me this tip and it worked great. You could quickly lube all these items up in an hour.
Axxis pads tend to be squeeky, i had a set on my integra back in the day with new rotors all around, and the car sounded like a train when its coming to a stop after about 2 months or so! I was annoyed with it, but didnt care to fix it so i sold the car with the squeek. They still stopped well.
What's anti-seize?
http://www.neverseezproducts.com/regulargrade.htm
NS-10 is the one ounce tube. Manufactured by Bostik
when I installed my aftermarket brakes and rotors.. i got new noises.. rattle.. clipping.. etc..
do I have to install other items too when replacing with aftermarket slotted x-drilled rotors..?
I know my rear calliper clip is bend .. need a new one.. (any suggestions where to get one;;;price??)..
Thank ALLLLLLLLL!
Thank ALLLLLLLLL!
The "anti-squeal clips" and the two shims per pad are independent parts of the brake assembly. They should always be reused and replaced as needed by new dealer parts.
Because the pads are not OEM, does not mean you can eliminate the shims that work with them.
I know this is a little off subject but.... I use simple green and spray down the brakes every week before I wash the car and it seems to be a good preventative maintenance to keep all the dirt and dust out of there. Just thought I would mention this cause I have always had nice and quiet brakes. Anyone else??
I am not sure if you have replaced your rotors and brakes with cross drilled and slotted rotors, but I have the same problem until they get a little warm. Once I have them warm they go away, but I do know that sound....kind of like a train.
This is my experience, oh and I am running the cerramic AXXIS brakes as well with cross drilled and slotted rotors.
Cheers,
Revhard191
Just my 2 cents worth...
recently downgraded from axxis ultimate to axxis deluxe
no squeeking... well maybe there is some, but its so faint and low. very happy... i guess i'll wait 2 months and see what happens
i recently bought a used gs4 and my brakes squeek alot too....mainly the front brakes when i brake a low speeds and when i am braking when i am in reverse....not sure what type of pads i got, but the previous owner said he just put on new rotors....they are not BBK, they look stock actually...maybe he didnt use genuine lexus pads....any tips on what pads i should get?
Originally Posted by Revhard191
LEXISM,
Cheers,
Revhard191
Cheers,
Revhard191
yes they only squeal until they warm up ...but damn it bugs
Im using Axxis Deluxe pads and 88 rotors X-drilled rotors
....no SS Lines didnt know how to install
I'll get them done next time i do My oil change
photomaker
IS F (2008-2014)
16
02-10-11 12:06 AM
