Help guys! What is this?
don't know exactly where that goes but i'm sure you need it.. it's a pin to keep a screw/nut from coming un-done while you're driving.. maybe it's one of the nuts that holds your caliper in place.. who did the work for you? best to get it back on asap lol.. good luck
-david
-david
Originally Posted by ILOVEGIRLS
check your lower ball joint and control arm. that is most likely where it is going to be.
Looks like the pin for the rod that holds the pads in place for the rear brakes. Im not sure if its in the front as well. Im puttin new pads on today so Ill take a look. Ill take a pic to show you as well if i see it.
HERE I COME TO SAVE THE DAY (even though someone else got it right before this)
Hope this help you put that pin back in place. Dont want your car to fall apart like a house of cards!
Right behind the rotor towards the rear
Or
Sorry for the crappy pics. Took it with my phone.
Or
Returd
Suspension and Brakes
12
09-12-17 06:04 PM
95gs300
GS - 1st Gen (1993-1997)
08-08-07 07:15 PM
