how much camber are you running?
Mortgage Slave
Originally Posted by TurboTeg
It's toe that will eat up tires fast not camber.
Originally Posted by roo
i agre 43289473298749823794723974% with teg, make sure you're toe is good and you're good to go. Toe is what kills the tires, not the camber.
Sorry, just confused and would like some clarity
Neg camber will still wear your tires more on the inside than at 0 deg. because thats where most of the preasure is applied. But toe will definately eat up your tires because they drag when not aligned properly...imagine each tire pointing in every direction
oh definately... i guess what I'm asking is... if my toe is aligned properly but I still have this -5 degrees... can I still get at least 85-90% of the tread life I would have if I had proper camber AND I FLIPPED the tires once one side (inside) wore out?
I'm not sure the % of life you will get. I plan on flipping my tires as well when I start to see wear.
Neg camber will wear your tires faster than an oem alignment. Toe that is way out of spec will wear your tires 20 times faster!
When I first bought the car, my front toe was way out and LCA bushings toast, and I went through a set of tires in about 2000 miles.
Maintenance Moderator
Originally Posted by ummagawd
Believe it or not... i can slide a credit card through that and still roll ! (used a bat to pull and roll... remember fenders are already shaved)
Driver side.... you can see where I messed up the pull (thats what i get for doing it with a bat)
You can also see this little bulge on the inside... this is what I'm talking about that hits my tire on the driver side... is it safe to hammer this out?
gman44116
01-04-10 08:32 PM
