Read this before you install new brake lines
I installed my Goodridge stainless steel brake lines today and it took a lot longer than expected. It seems that the threaded nut that goes onto the brake line from the hard lines has a flare on the end of it that gets stretched after years of use. The only way to get it on the brake line is to grind the flare down very carefully with a dremel or similar tool. I wish I knew this before spending 3 hours on a job that should have taken 30 minutes
Originally Posted by KidPandJ
Wow that sucks, I'm glad I didn't have that problem on mine. How do you like them, now that you've got em?
Originally Posted by actuary
I only got the rears on so far so I dont feel much of a difference. I'll be putting the fronts on with new rotors and LS400 calipers so I won't be able to pinpoint the change just from the brake lines. I got all the parts ready to go, just got to get some time to do it.
Did you use an actual flare nut wrench for the job or just a typical crescent wrench?
Brake caliper change
Act,
You mentioned you were going to install LS400 brake calipers. Is that on an SC400? How is that a better caliper? Will it fit with stock rims? Are you using the stock rotor? Lastly, I read a post where the Lex pilot installed a large caliper and rotor and he said the difference was phenominal and that his ABS would not function. Will your ABS function?
I have a 92 SC400 and am curious about my opyions and what else I have to change.
Thanks for your post.
John
John
I did the LS400 brake upgrade, and had the same problems you did. Only i made my upgrade worse by breaking the hardlines after getting annoyed with removing the old brake lines. So i decided to go with stop tech SS lines and had to bend my own hardline to replace the broken ones. If you break them at least the lexus dealer near me had the part on backorder for 2 weeks so be very carefull and save your self the trouble.
Originally Posted by JohnEd
Act,
John
John
John,
You will need the 95-96 LS400 rotors ( cheapest are on rockauto.com ), calipers ( buy rebuilt loaded ones with pads from advanced auto etc and turn in your core ), And while your at it pick up some front stainless steel brake lines from stoptech. You must have high disk fitment wheels (ie supra tt wheels) in order for them to clear. Also you need to cut off the dust, very simple and easy to do.
Goodluck its a way better value then the supra tt brake upgrade. Both the LS400 and the Supra TT calipers are four piston.
This is what happens when you buy non zinc coated rotors and it rains.... haha
flair fittings
Guys,
In the past I have also had trouble getting fittings to go back together. Once in a while I had trouble getting them to come apart. The reason flairs seemed to grow is that the fiting is over torqued by the guy that tightened it last.. All of the brake fittings I have seen have a double flairs on them. Filing them down to reduce their stretched or pressed increased diameter will put you close filing a flair in half. Whether this would leak or break I don't know. It can't bode well though for the brakes. I think you will end up with a single flair and all breaks are required to be double flair.
Over torqueing was much more of a problem in the past when we worked with copper fuel lines. We learned quickly that over torquing a fitting would create a permanent joint.
Just some thoughts.
John
Just some thoughts.
John
Overclocker
Suspension and Brakes
09-13-05 06:02 PM
