Pro-Act Brake Pad Install Question
Old 07-16-06, 06:57 PM
Dryrunner
Dryrunner's Avatar
Default Pro-Act Brake Pad Install Question
The Akebono Pro-Act pad comes with a glued on anti squeal shim. Do you also install the OEM slotted inner anti squeal metal shim?
Or just glue on the Pro-Act shim and install into the caliper?
Thanks,
File Type: pdf
Old 07-17-06, 06:15 AM
Tammy
Tammy's Avatar
Yes, use both the inner and outer shims with the new pads, even though the pads have a plate glued to it. Be sure to grease the shims and the pad mounting points, prior to reinstalling. Interlocking shim tabs are installed away from the disk; both sides.
The two shims per pad are part of the caliper assembly, independant of the pads. They are always reused.
Old 07-17-06, 02:22 PM
Dryrunner
Dryrunner's Avatar
Thank you.
Xin
RC F (2015-present)
04-23-18 08:10 PM
Lazyj321
12-30-15 02:47 AM
PTCS
Wheels, Tires & Brakes Forum
11-15-14 07:28 PM
LXotic
Maintenance
07-16-13 06:44 PM
fujxyooj
04-18-13 04:01 PM
Quick Reply: Pro-Act Brake Pad Install Question
