clear coating calipers in hot weather
i just bought a can of clear coat 500 degree... but its hot as shiiatt outside... NYC, 95 degrees, feels like 100-105...
and i wanna put on my lexus decals for the calipers then clear coat them... should i wait for cooler weather?
Originally Posted by djjt
oh yeah, one more thing... i'm kinda lazy and my body's sore from working out...
should i take off the tire and newspaper away everything then apply the coat?
make sure you mask out everything else after taking off the wheel, you are good to go
Master Thread Closer!!
The hotter....the better....that means it will dry alot faster.
As for being lazy....thats probably 90% of everyone here...LOL!!!
Hmmmmm....taking off tire....well I hope so.
Instead of newspaper....try using an old t-shirt.....put calipers thru where your head opening...covering the rotors and top hat....maybe use a car cover the protect the fender panel.
Pete
Pete
Might as well do it right and remove everything. Its really not that bad. Although I went ahead and did mine when I was installing my rotors. Looks much better, especially when someone wants to zoom in close.
ohhhh wtfffffffff
i had to take out the pads???
i already did them, but didn't take out the pads... i'm guessing I'll have trouble changing brake pads later on?
again it doesn't mean everything is damaged, but if i were you i woudl take everything apart (the clips, the pads, etc...) to make sure they are good
