CRAZZZY SHAKE While BRAKING
Old 07-25-06, 03:33 PM
bollywoodk
bollywoodk's Avatar
Default CRAZZZY SHAKE While BRAKING
Yes yes, I know this is an old issue, bUt my gs3 '01 is still being stubburn about the shaking while braking story..
Here is what I have done:
- Changed Tires
- Balanced with GSP9700 machine "Twice"
- Changed my struts
A tech told me (third party) there is a leakage from my lower ball joint. Does anyone know how much this cost (Any hook ups in NYC area)?? Or should I just buy the Daizen Bushing Kit (does it come with the ball joint)?? COULD this be the issue of the shaking??
Does anyone know where I can "shave" my rotors also.. I have 88rotor cross drilled slotted rotors.. (NYC Area)?
Thank all for help.. Sorry I am not a certified LEXIE yet.. Soon though with all your help.
Old 07-25-06, 03:49 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,271 Likes on 1,378 Posts
It's likely your brake rotors. As you say, you need to get 'em turned or get new ones.
Old 07-26-06, 05:51 AM
GeorgeGS4
GeorgeGS4's Avatar
ball joint's usually cause a clunking sound when bad, not a shake while braking(although if the boots teared, it needs to be replaced regardless) But if the wheels shaking while your hitting the brakes, your rotors are most likely warped and need to be replaced.
Old 07-28-06, 01:16 PM
black_gs99
black_gs99's Avatar
I was told by basil head mechanic at t-lex that on most lexus's the calipers go bad and cause the car to shake. well atleast on my car. i changed the rotors and it didn't help and then i changed the caliper and now there is no shaking/vibration at all...Does your car vibration/shake at 52-60 mph?
Old 08-01-06, 01:00 PM
bollywoodk
bollywoodk's Avatar
My car starts to shake at 55-70 then when I brake slighty.. it goes crazy.... My rotors are 8 months old.. with 10,000 miles on them..
HELPPP>> I want no shaking.. PLEASEE
Old 08-01-06, 01:19 PM
eman88
eman88's Avatar
I just had the same problem on my 01 430...shaken wild at higway speeds while braking....I changed / replaced the lower ball joints (both sides), tie rods (both Sides), rotors (all 4), and upgraded to ceramic pads. and come to find out the problem was that one of the bolts on the caliper bracket was frozen in the sleeve, I had to take the bracket to a machine shop to have them take out the bolt and re-grease and install a new bolt, after I reinstalled the brakes I had no shaking at all.....it seems the bolt being stuck in one position pushed the caliper out of alignment and caused the wheels to shake when braking
Old 08-01-06, 02:15 PM
bollywoodk
bollywoodk's Avatar
Thanks EMAN-- Where did you take the car in local NY.. ??AND what exactly was done?? and how much did you pay?? Do you know good and reliable guy to work on the Lexis..
THANKS ALL..
Old 08-01-06, 02:54 PM
TLW
TLW's Avatar
I will say this ..If you drive "aggressive" you will warp rotors quicker
Old 08-01-06, 03:19 PM
sbgs400
sbgs400's Avatar
i have a somewhat similar situation, my gs4 was vibrating badly with braking, i've changed all 4 rotors and put on new pads and it's still vibrating. the calipers *seem* to be working properly with no sticking.
Old 08-03-06, 07:38 AM
bollywoodk
bollywoodk's Avatar
ANYONE IN NY got this fixed yet?? Where at??
Old 08-03-06, 11:07 PM
ShaneC
ShaneC's Avatar
i had the same problem. braking at around 65 mph the steering wheel shake like crazy. so i decided to upgrade to brembos big brake kit. all better.. no shaking..
Old 08-04-06, 03:10 PM
BA_GS400
BA_GS400's Avatar
I'm a little surprised that no one mentioned the bushing thing.
I think that generally speaking, that vibration is *usually* the brake rotors. Easy to check, easy to fix. There are a few other things that cause it as well, like what has been mentioned above.
For me and a few others I're read on this board, that vibrating feeling you feel so much in the steering wheel turned out to be the bushings. Yes, this was during Braking, even though we had a lesser vibration when at the dreaded 50-70mph speed.
I know that on my car, I found that when I was braking at normal pressure, the vibration was there, but when I went with more aggressive braking, the vibration practically went away. We're not talking squealing tires or anti-lock, just more than most "non car-guy" types would use when braking and enough to make people in the car say "what are you doing?".
Old 08-04-06, 03:53 PM
SoCal_VIP
SoCal_VIP's Avatar
I had the same problem. Mine was bad to the point where when I would brake it would be hard to keep the car traveling straight under braking arounde 20 mph lower. I was in need of tires so I replaced all four, still shaked. Had the alingment done and wheels re balanced, still shaked. Finally I took it to Lexus and they told me I need new rotors. So I went to a local brake shop that one of my friends recomended and had the all 4 rotors re surfaced and new brake pads. No more shaking at all It's your rotors bud
Old 08-05-06, 10:06 AM
bollywoodk
bollywoodk's Avatar
Thanks all. I will replace rotors.. any cheap butGOOD after market rotors recommended.. I had the 88rotors crossdrilled and slotted.. (i hear they cant be surfaced) so I guess new rotors it is..
Anysuggestions??
kings222
IS F (2008-2014)
30
04-19-23 01:00 PM
ishootstuf
Suspension and Brakes
35
02-02-22 03:54 PM
ThumperPup
ES - 5th Gen (2007-2012)
04-17-18 01:26 PM
Eds98LS
25
05-07-13 06:21 PM
STONER
06-09-05 10:43 AM
Quick Reply: CRAZZZY SHAKE While BRAKING
