Rear upper CA helpful hint!
#31
Front & rear bushings Are different between uca's, Protane sells kits for front & rear or a complete set for the car. Just did my rear end in September, used new cam bolts for Supra. Some people lower rear sub to get to rear uca bolts. I just used sawz-all & cut the bolts and bought new ones for uca's. (Supra bolts) Wasn't to bad of a job considering she's a Pa car thats been in the salt.
#32
I just replaced all of mine last night by myself. I got so frustrated trying get the old one's off that ended up grabbing my handy saw zawl and got the entire control arm in 3 pieces right before the ball joint and bushings. Thank god i had a set of 4 from a 98 Supra T.T. Trying to get the nut and washer on the bolt was F'n ridiculous. I honestly probably spent an hour and forty- five minutes. Once you drop the nut that is when all the fun starts. If you are lucky the washer might fall, keyword might. Good Luck to all of you contemplating doing this. It is honestly one of the most frustrating installs that I have ever attempted on a car.
