Brakes are diffrent on the ISX50's?
Old 07-28-06, 11:26 AM
SPEED&ECO.
SPEED&ECO.'s Avatar
Default Brakes are diffrent on the ISX50's?
Hey im not sure but are the brakes diffrent for the IS350 and 250? I read somewhere that they are.
becuase i want to get aftermarket pads but not quite sure if they will fit becuase the part says is350.
Old 07-28-06, 11:31 AM
conekiller
conekiller's Avatar
yes, different
pocky
mooncake master
pocky's Avatar
Yes they are different.
IS350 is 4 piston.
IS250.....Not sure. 2 pistion? Can anyone correct me?
Old 07-28-06, 11:38 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Yes they are different. They are four piston front caliper.
Rotors
IS350 - 13.1 Front
12.2 Rear ventilated
IS250 - 11.6 Front ventilated
11.4 Rear
Old 07-28-06, 11:39 AM
SPEED&ECO.
SPEED&ECO.'s Avatar
so then aftermarket pads for a is350 will not work?
Old 07-28-06, 11:45 AM
pocky
mooncake master
pocky's Avatar
Well, let me think about it real hard. I have a strange hunch it will not fit on a IS250.
Old 07-28-06, 12:01 PM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
No they won't the IS350 pads are bigger than the IS250.
Old 07-28-06, 12:19 PM
SPEED&ECO.
SPEED&ECO.'s Avatar
crap then im stuck with stock pads.....
Old 07-28-06, 02:04 PM
Payam
Payam's Avatar
You could always upgrade the whole brake system... But then your talking a lot more money...
Old 07-28-06, 02:06 PM
Pittdawg
Pittdawg's Avatar
Anyone know how simple this is, is it more or less a direct swap or more involved?
Old 07-28-06, 03:55 PM
SPEED&ECO.
SPEED&ECO.'s Avatar
seems easy but i think the parts alone are extremely pricey
Old 07-28-06, 04:29 PM
al503
al503's Avatar
OEM parts are usually very expensive. The biggest question is whether the mounting brackets for the calipers are the same on the 250/350. If they are, then it shouldn't take longer than an hour a side taking your time (if you've done this before.) If they're not, then custom brackets need to be fabbed and then you would be better off with an aftermarket bbk.
Old 07-28-06, 07:25 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,068 Likes on 2,465 Posts
Not only that, but the fluid volume is different, so the ABS won't work right unless you swap it too. Stoptech has a great white paper on their site about this issue. It's just not as simple as sticking a different caliper on an existing system and having it work right.
Old 07-29-06, 12:32 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Yes just keep your stock brakes. . .
Old 08-03-06, 07:55 AM
ISbb
ISbb's Avatar
I personlly think the breaking of my IS250 is very good!! Maybe I have never try so hard on it yet...
Quick Reply: Brakes are diffrent on the ISX50's?
