Any good springs besides Eibach?
I'm lookin to lower my car, i've read a few threads on how eibach continues to settle in over time and I dont want that on my Lexus.
What other springs are out there that people recommend that won't settle over time?
thanks.
thanks.
mooncake master
I believe H&R just came out with their Sport Springs. It will definately be lower then the Eibach Pro-Kit.
Also, TEIN should be releasing their H TECH & S TECH soon. The H TECH is a more conservative drop.
But all springs will settle just a little over time. That's the nature.
With the only reason (around here) for going with a different set of springs is to lower the car, seems the springs "settling in" would be desireable? I mean, less wheel gap is the most important thing, no?
Just depends on how much you want to lower the ride and you have to consider alignment, stock shock compatibility, as well as clearance for some. I'm looking at the tein h-techs (advertised 1" front, .6" rear drops) for a nice subtle drop that will even out the difference in the stock wheel gaps. After settling, add another .2" or .3" and you 'should' be able to get the alignment back in spec.
efini_kid
21
10-04-05 03:00 PM
