tt calipers q's
im buying some front tt calipers and brembo cross drilled rotors, i currently have 18x5 inch wide rims on my sc4, will my current wheels clear the tt calipers??
to fit tt brakes you have to have high disk front wheels. offsets dont make much of a difference except for fitting in the wheel well. find out what disc set you have for your wheels and that will tell you if you can run them or not.
thanks chawk.
hun, they part your looking for is the spokes. you need about 2.5 inches of backspacing to fit the calipers. Im running the tt's behind some tt rims and they have only like 3mm of clearance just so you know they are a tight fit even on high disk. Look at how cut out the back of the spokes are and take some measurements, thats the best advice I can give.
thanks chawk.
Hun, I went around with a ruler and micrometer trying to get the measurements. In the end, the only sure way was to do what I said with checking on someone else's car. Turns out I have 2-3mm of clearance
, but it is clear. Show us a pic of the front of the wheel rather than back. That's a better way to tell than looking from inside. It's all about the face design.
svt5150
Wheels, Tires & Brakes Forum
06-29-07 08:45 PM
supradean
SC- 1st Gen (1992-2000)
02-26-07 12:21 PM
