does any ones sc vibrate while youre driving?
Vibration could be caused by numerous things, Like said above if you feel it in the steering wheel at highway speeds, its likely the front tire balance, if you feel it in the seat and the whole car shakes it could be something in the rear end or driveshaft. Try getting all 4 wheels balanced at a good tire shop and change the rear differential fluid. Also check the condition of your engine/transmission rubber mounts, i've seen when those wear out it can cause some vibe.
You lowered? Did you have an alignment done after lowering? If not, that is your problem. I lowered and had laser alignment done but I still a vibration in the steering at 70mph only, not at 65, not at 75, not at 80, only at 70. I have yet to have my front tires re-balanced, they haven't been in a couple years.
My transmission mount looked alright upon inspection but I decided to replace it anyway. After my bro got the transmission mount off, it was in two pieces!! After that, no more vibration between 30-45mph range.
~Josh
~Josh
I feel a vibration everytime I apply pressure on the brakes. When I apply the brakes slowly, the steering wheel begins to shake and I feel below my foot pulsulating so to speak. Anyone know what problem this might be?
