View Poll Results: Stock vs Sports Suspension
Stock Suspension
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
84
40.98%
Sports Suspension
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
121
59.02%
Voters: 205. You may not vote on this poll
Stock Suspension VS Sports Suspension
#46
ISbb > For your information, the dealers here also sells Eibach springs as a dealer add-on option, i guess you can considered that qualifies as "being as OEM as possible"?
The handling of the sports suspension will be firmer than the standard, but it won't lower the car that much, and I guess if looks are important to you as well, you might be dissappointed with this choice.
X-package/sports package Sport Suspension:
-10mm lower front only
-5% stiffer shocks f/r
Eibach prot kit
- 1.4" lower front and rear, stiffer spring rates than sports suspension
So if you already have the sports suspension, getting ebachs will lower your car a further 0.9" for a total of 1.4" drop, and you already have a stiffer shock from the sports suspension to compliment the stiffer eibach springs.
Eibach prot kit
#47
The FSM says the ride height is 10mm (0.396") lower and only on the front. The rear ride height is spec'd exactly the same for sport and standard as long as you have the same diameter wheels. Actually the spec for the 16 and 17 inch wheels is lower than the 18" wheels by 8mm and 6mm respectively.
didn't find it on the website.
#48
FYI- the reason I think the sport package is worth it-
It costs hundreds of dollars -less- than the luxury package with 18" wheels, but it gives you all the same options except the woodgrain (which I don't want) and the power rear sunshade (which also seems useless).
So Lexus is paying you $500 to give up the wood and sunshade, but gain the better springs/shocks. No brainer to me.
#53
Having driven several IS350/250 with lowered springs, I'm glad I'm ordering my IS with the Sport package. The only other coilovers I would use would be the HKS Kansai service coilovers. They are lighter (aluminum body) and are rebuildable. The valving is suited to match the spring rate and just like the HKS hipermax coilovers on other cars, they will probably not jarr your teeth loose.
Since the ISx50 RWD doesn't have adjustable camber, I'd leave the suspension at stock height of a sport suspension model.
#56
Now that we have 08 IS350 twins, one with the sport package, the other with the luxury package, I can make a back to back comparison. BTW, the luxury has 18" summer tires, the exact same that are on the sport.
My findings...
The sport is a bit stiffer over bumps, has some less body roll in turns, provides for more road feedback, and has a slightly different steering feel (a bit tighter). The wheel vs fender gap has the sport about 2/3rd an inch lower than the luxury.
On the other hand, the luxury handles great, provides enough feedback, is also precise in steering, holds the line, and has body roll that is still far less than most other cars.
I'd say that if the sport is 100 in terms of overall handling, the luxury is 90.
My findings...
#57
My findings...
My findings...
Does the wheel gap in the luxury setup detract at all from the great looks of the car?
Unfortunately my local dealer has no 350s presently on site so I can't do my own live comaprison.
#58
Thanks for the report. I'm in the process of beginning a "special order" IS 350 and opted for Luxury Pkg. I prefer comfort with some sportiness on demand. Maybe ten years ago it would have been the other way around. It would be great to see a profile or angled-front photo of the two setups side by side to see how noticeable the suspension differences are.
As for the wheel gap, I just looked (again) at both cars sitting in the garage. Again, only marginally noticable. At a glance, one can't really tell the difference.
Using a 100 point scale, up to 85, the sport and luxury compare equally, the ramaining 15 points plays out like this...> luxury is a slightly softer ride with a slighly looser steering ratio but still precise... sport is marginally firmer, slighly less body roll in hard turns, slightly tighter steering ratio.
#59
When I was looking at cars, I drove a few Lux package cars...I didnt like the wood, just my personal preference. The non Sport package cars drove fine...I looked at the Sport package car with my wife expecting NOT to like it....it was clean, and we liked the interior without the wood alot better visually. Then we drove it....and I LOVED it...responsive, but not harsh at all. My wife who HATES rough riding cars preferred it. She said the car just felt smoother. I liked the responsive steering. I plan on adding lower springs and the Sport shocks may actually work out better than the Lux shocks.
