Vibrates like H**l
#61
I had similar vibration problems. I brought the car to Lexus two times. They did not fix it properly. Then I took the car to Town Fair Tire for balancing. The vibration was gone.
Mark
Mark
#62
I will also have the front brakes check. You could have a possiable warp rotor. I think Lexus should have put cross drilled and slotted Rotors on from the Factory. I think because the car is so big and heavy, when drive fast only daily bases it cause the Rotors wear faster. But this is just another thing you might want to check along with Tire balancing or a bad Rim..
I also have a bad vibration but I think it's the rotors that are causing my some of my issues. Then also maybe I need to start driving like normal people <funny> not I.. Have a nice one...
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#63
My steer wheel shake like hell when braking from 70-50.
Wrap roter? I just had TRD brake upgrade about 2 month ago? already wrap? Dealer was telling me that I need the roter resurface... what? only two month....
#64
Are they the Cross Drilled and slotted Rotors? They should not have warp that fast. They should not need to be resurfaced that fast. Unless you drive over 130mph everyday. Did you order the rotors from TRD?
#66
Is this setup part of the group buy that is going on now by CL?
I just order those this week from Steve. I thought they were slotted and cross drilled? I would send them back. Well my car is doing the same thing right now. But I figured I needed to but the rotors and new pads on. What pads did he set you up with?
#67
No.. its just sloted roter and trd sport pad. I think the current GB is the supra brake upgrade.. that is diff.
Send back to Steve? hmm...I don't even have the stock one to replace.. so I might have to get them resurface to see what is going on....
#68
I just sent Steve an email I want to see what his responses is going to be? Well try re-surfacing the rotors an keep us posted. But you should not have to had that done for at least 6 months. Put It really depends on how you and the misses drive. But it don't sound like you drive fast at all.
#69
Well, here is an update on my noise and vibration problem. I took it back to tire shop to have tires rotated and have alignment checked again. Front alignment was way out and shop said that back was a little out but he could not get it back in but that rear tire wear was not bad. I left and noted that the steering wheel was not straight when the car was going straight. I immediately took it back and explained to the alignment guy what I noticed and he immediately realized that the problem was the rear alignment. He put car back up on the rack and he had to work with the right rear wheel for nearly an hour before being able to get it in-line. Car drives fine. Much of the tire nose is gone. There is still a high pitched howl which seems to resonate in the front end at around 15-30 mph but I can accept that this is "tire noise". I am running Yoko AVS-dB.
I still think there is a problem with the front end design that amplifies tire noise.
Vince
Vince
#70
Congrats vroman on getting some improvement and thanks for the update.
I do think the GS alignment is very sensitive.
#72
For those of you who are experiencing excessive vibration/shimming problems. Please consider having your tires/wheels checked by any dependent tire shop that may have the following:
Hunter GSP9700 Vibration Control System
Using the Hunter GSP9700, may resolve some of those vibration/shimming problems. As the GS suspension is sensitive to incorrectly balanced tire/wheels.
#73
Over the last weekend.. I was soooo sick of my bad vib when I brake from high speed, the whole car would shake.. so I rotate the front wheel to the back.
Stupid move... now I feel the shake not only when I brake.. but when I drive on highway.
I think I may have combination problem.
1st: my new TRD roter might be wrap? (Vib on Brake?)
2st: the back wheel are not balanced correctly?
my dealer was telling me that I need to roter re-surface to fix the vib on Braking?
I am going to get the tire re-balance and allign tomorrow or sat.
Do you guys think the re-blanace + Allign will fix all my problem? or I have to find someone to re-surface my 3 month old TRD rotor?
