Camber Kit?
Old 09-13-06, 06:15 PM
punch10
punch10's Avatar
Default Camber Kit?
Does anyone sell a rear camber kit for the GS? I am running 1.5 degrees of camber on the rears and would like to run 1 degree. The best I could get on one corner was .8, the other side wouldn't go beyond 1.5.
Old 09-13-06, 06:20 PM
LEXSOOS
LEXSOOS's Avatar
No camber kits avalible yet and probably never will , sorry
Old 09-13-06, 10:45 PM
rominl
exclusive matchup
rominl's Avatar
adjust your toe to minmize inside wear by the negative camber
Old 09-14-06, 07:38 AM
punch10
punch10's Avatar
Toe is at just about zero. I am a little irritated that the best I can do on the right side is 1.5 degrees. Is everyone else having this problem?
Old 09-14-06, 09:36 AM
rominl
exclusive matchup
rominl's Avatar
putting toe at zero is a bad idea. on lexus you always want it to toe in a bit, that's the right spec. and if you lower the car more and has negative camber, you toe in more
a good alignment shop will do that (if they know what they are doing)
Danilo02
Suspension and Brakes
07-16-15 11:51 PM
i2fat
05-11-15 03:14 PM
SPEED&ECO.
01-28-07 02:40 PM
FutureGS400
08-25-04 01:44 AM
One HoT
11-07-02 02:20 AM
Quick Reply: Camber Kit?
