rear brake warning light does not go out
Old 09-17-06, 10:24 AM
jboy
jboy's Avatar
Default rear brake warning light does not go out
Hi,
I have a 2020 GS 430 and the rear brake light warning indicator on the instrument cluster is illuminated. I checked and a bulb was burned out so I replaced it. However, the warning idicator is still illuminated. Any thoughts?
Old 09-17-06, 12:55 PM
PHML
Master Thread Closer!!
PHML's Avatar
Make sure you check everything.....3rd brake light, inner tails, etc...
Reset ECU by removing negative battery terminal for an hour or so....then reinstall.
Pete
Old 11-10-06, 01:18 PM
THE_CEO
THE_CEO's Avatar
yep i just changed a bulb and had the same problem...does this work?
CEO
Old 11-10-06, 04:22 PM
lalexusgs
lalexusgs's Avatar
I had the same problem, and it turned out to be that I just bought the wrong bulb. Make sure your new bulb has two little lightning "spirals" inside, not one.
Old 11-13-06, 03:40 AM
JeffTsai
JeffTsai's Avatar
Yep don't get the wrong bulb. The Brake lights have dual filaments. I believe 7443 is the correct bulb size. 7440 is the single filament for turn signals and such. Good luck on the fix!
Old 01-22-14, 10:12 AM
RamAirRckt
RamAirRckt's Avatar
What bulb goes in the trunk brake light? (you know, the ones that go pink with age)
I can't confirm if it is a 7440 or a 7443 and only 1 filament used. Seen that done enough on other cars.
Old 01-22-14, 01:17 PM
shboni
shboni's Avatar
Originally Posted by jboy
Hi,
Whoa!!! 2020 GS you from the future dude?
Anyways, having this same problem. My High mount brake light bulbs were burnt out. I replaced them but still have warning indicator. Some one suggested that I need to use I believe 168 instead of 194 I think
Any thoughts on this guys???
Old 01-22-14, 01:20 PM
shboni
shboni's Avatar
Just notice this thread is from 2006
Oh well still valuable question/information...
THREAD BUMP
jonathanrn
RX - 1st Gen (1999-2003)
01-10-18 08:24 PM
Matthew
26
04-18-12 11:13 AM
worldforgo
04-02-11 06:53 PM
RX300Scott
01-18-11 09:56 AM
gerbjones
08-31-05 12:12 AM
Quick Reply: rear brake warning light does not go out
