supra lca's!
just compared the dazian bushings with the bushings in the oem supra control arms, and the bushings in the supra control arms are larger, so the dazians will not work in the supra control arms! however the bushings in the supra control arms feel and look alot harder than stock sc bushings.
it would probably be cheaper to buy the supra control arms and have a shop install and perform an alignment. the process of burning out old bushings and replacing them in the stock lexus arms will most likely cost more. i got my control arms from carson toyota 460.00 shipped!
If your car has over 150k then the ball joints are most likely shot, replacing the bushings will only be a temporary fix and you'll end up doing that same labor again in less than a year. Just save yourself the hassle and replace the lca completely. How do I know this you might wonder?....ahh yes, how do I know this...
I was just speculating that it would be cheaper to have daizen bushing installed on your SC's LCA (+ new ball joint) compare to brand new supra LCA assembly from dealer. Thanks for the explanation. :-)
I work in a speed shop so labor is free. yes I would torch the rubber than use Snap On hammer to tap it out.
