FEEDBACK NEEDED: Tanabe Sustec Pro S-0C Coilovers
Does anyone have experience with Tanabe Sustec Pro S-0C Coilovers WITH HELPER SPRINGS?
Based on what I read on THEIR web site, the ride comfort is enhanced due to the double (outer and inner) springs. Does anyone have these installed on a 2nd Gen GS? If so, how do they compare to stock? Or how do the compare to ESPELIR / KYB combo?
Thanks!
Thanks!
GS300/400 (JZS161)
Spring Rates F/R - 14.0/12.0 , *Rear mount included
Height Adj. F/R* +1 1/2~-1 1/2in
Sustec Pro S-OC
For those who desire both high performance with maximum ride comfort, we offer the Sustec Pro S-0C. The short stroke / short case dampener delivers superior handling without sacrificing strength or ride comfort. Double-cylinder valving design allows for a full stroke within the extremely short case shock body. Low-pressure gases ensure smooth rebound characteristics for even more ride comfort.
Street-tuned Coil-Over Suspension System Kit engineered to deliver a comfortable ride.
Rubber Upper Mount (optional)
Optional upper mounts with rubber inserts absorb vibration and shock are a great upgrade over stock rubber upper mounts that improve handling and response.
Helper Spring
Smaller distinctly-colored helper springs allows for greater flexibility in determining the desired ride height. Prevents pre-load of the main spring when the height is raised as well as excess slack when it is lowered. This ensures a comfortable ride.
Short Stroke / Short Case Design
S-S and S-0 are designed with a short stroke / short case shock absorbers that deliver superior handling without sacrificing strength or ride comfort.
Sustec Pro S-OC
Helper Spring
Thanks!
Thanks!
Big C
16
09-10-10 06:54 PM
sdpq
08-28-07 05:05 PM
