Should I get the Supra or SC Tokico shocks?
I ordered the Supra Eibach springs for my SC since they seem to set lower than the SC Eibach springs, what I'm wondering is which shocks is best for me to buy to compliment these springs on my SC400.. Is there much of a difference or would I do good with either of them?
Any OEM and aftermarket suspension designed for the MKIV Toyota Supra will also work with the SC coupe. This includes all Supra coilover packages. Ony thing you must consider when shopping for Supra lowering spring packages: you must swap the entire strut-spring assembly from the Supra rear end, not just the springs. Meaning if you purchase Eibach Supra Prokits, you must also purchase Supra-compatible strut shocks, because the rear strut perch on the Supra sets lower than the rear strut perch on the SC. If you attempt a Lexus shock with a Supra spring, you will actually lift the rear end of the car higher than stock. The front struts are the same on both cars however. You have the option of buying the OEM Supra shocks (cheapest), or aftermarket Tokico, KYB, etc shocks. It is recommended that you replace all four shocks together for uniformity, instead of just the rears if you go this route. Supra NA and TT shocks will fit the SC300 and SC400 fine. You do not have to worry about these compatibility issues when you buy Supra coilovers.
Info from http://www.intellexual.net/faq.html#12
