How low do these TEINS drop the car?
19x11.5 -51
Well If it helps .. When I first purchased the tein Has.. that are for sale I had left the setting where it was when I bought them ..
Seemed as if I was running on air ... I kept lowering the jack and was Like OMG !!! I knew it was Not driveable but seemed as if I was tucking the rim ... 19 8.5 n 10 ....'
How low are you looking to go ?
wish I had those pics ;/
you should be able to tuck 20s with no problem. I got the cs which dont lower the car quite as much as the flex, ha, and ss, and if i took it all the way down id be tucking 20s on those.
There can only be One
SS I think are the only ones beside the Flex that you can Tuck.
I know the CS2's you cant. I tried on mine.
Good luck with that negative camber and new tires every 6 months. =)
