Should I put the Daizen Bushings on TRD Sways
I'm going to switch sways from Daizen to TRD and wondered if anyone has used
Daizen Sport Tuning
Polyurethane OEM Sway Bar Bushing Kits
Very economically priced upgrade that improves handling noticeably without a full sway bar upgrade. Uses existing OE brackets, sway bars and hardware. Permanent solution to worn rubber bushings. Direct replacement kit services one vehicle and contains front and rear bushings, special synthetic chassis grease and instructions.
Also I read where one member had his sways on upside down for a while.
Does anyone know of a link for installing the TRD Sways.
Thanks
Ivan
3dog
Daizen Sport Tuning
Thanks
Ivan
3dog
Daizen Sport Tuning
Thanks
Ivan
3dog
Daizen Sport Tuning
Thanks
Ivan
3dog
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
I want to try the TRD Blue sways.
I presently have the Daizen sways on my car.
It seems like I've heard about people using the Daizen Bushings on the TRD sways but I could be wrong.
This came about because my wife had a Daizen rear sway bar break She took the car into a dealer who put a stock rear sway bar on her car. Well the car drives like ***** now with stock rear sway and Daizen front. I came up with the idea of switching my car to TRD and taking my Daizen rear sway and putting it on her car. So I bought a rear TRD sway from a guy on CL and ordered a front TRD sway from Swell in Dallas.
So today, in fact just a a short time ago I get a e-mail from Daizen saying they will actually replace the rear sway. I had e-mailed them like 10 days ago and did not hear anything so I was trying to come up with my own solution when I saw the TRD rear sway for sale on Club Lexus.
So now my dilema is do I go ahead and change over the sways on my car. Dollar wise it would be foolish. I've already spent over $500 to just get the TRD sways. I guess I can send the front one back to Sewell and try to sell the rear one on CL where I bought it. Maybe I should just keep the front one and try to sell them as a set.
The other part of the thing is I love for the car to be stiff. I have a set of JIC Magic coilovers on and have them set at max setting . Wife hates it but I like to be flat in corners and no bounce.
At this point I will probably just leave the Daizens on my car, and try to sell the TRD's as a set.
I'm frustrated right now but it will work out.
Ivan
3dog
Ivan
3dog
Can't believe that the dealer put a stock sway bar on a car that had an after market stiffer sway bar on the other axle. As you discovered, this creates a very unstable handling situation when the sway bars on the front and rear are not properly balanced with respect to one another. I would think they (the dealer) could have had a liability exposure if the unmatched sway bars had contributed to an accident due to unstable handling. They should have either replaced both or neither or used a properly matched bar for the broken one. There have been extensive discussions in the past about the merits of one brand of sway bar vs another. Everyone has an opinion. My feeling is, stiffer is not always better. Depending on other factors and components, going too stiff can actually be counter-productive to good handling response. If you want to get some expert opinion on suspension set-up and tuning, try contacting Double Whoosh (Tod M.) at TM Engineering. He is a sponsor on this site and posts as well. A great source of knowlege and inormation about suspension matters. Also a good source for parts and service. (No, I do not get a cut for endorsements).
The wife was leaving on a short trip to Oregon and took the car in to get an alignment. They called me and told me about the sway bar and I told them the front and rear were both aftermarket sways and I was concerned about mixing the two. Service guy told me the the Lexus Sway was a high quality product.
Well wife ended up taking the loaner on her trip which is a good thing. I drove her car Sunday and cannot believe how crappy it drives. Like you I'm sure the dealership would be facing some legal problems if there was an accident.
The Stock Rear Sway parts and labor were something like $540. I guess I will be writing a letter to the dealership pretty soon and asking for a refund. Yeah good luck with that one
The replacement Daizen Sway is actually coming from TM Engineering
Hey Thanks for the input.
I think I will leave the Daizen Sways on my car and I'm glad they stood behind their product.
First of all. I've mixed and matched Daizen, TRD, and Stock bars. Just to experiment. There is really no dangerous handling situations if you mix any of them under NORMAL driving. Obvioulsy, when you start to gun it thru the corners and such, the unbalanced sways will give you some screwy handling. Personally, I ran TRD rear and stock front, stock rear and TRD front. Daizen rear and TRD front, TRD rear and Daizen front. Hell, I've even ran for a week with no front sway when my end link bent in half
. They were all manageable with a few setups oversteering or understeering too much but not too badly. Note that this only happens at high speeds. Under normal street driving there is pretty much no effect since you're really not putting that much stress on the bars at low speeds. Honestly, I don't think your wife is going to be carving the corners or going 45+ mph thru a turn...so it's not too big of a deal to mix and match bars until you have time/money to get a full replacement. So long as you arent gunning the corners.
Mine came loose a few times as well. Afterwards, I just torque the hell out of it and use some loctite red. It will keep the nut on there pretty good. Only way to remove it will be with a high power impact gun.
Also, make sure that end link thread is not stripped already, if it is, you'll have to replace end link with self-locking nut at the same time
Good luck and enjoy your TRD sways
- Jake
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Mine came loose a few times as well. Afterwards, I just torque the hell out of it and use some loctite red. It will keep the nut on there pretty good. Only way to remove it will be with a high power impact gun.![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
I thought I would share it with you guys.
"Basically in a nutshell:
You can have any front sway bar on the car, with no rear sway bar.
In order from soft to stiff, none->stock->Daizen->TRD
Obviously the sway bars are matched, front and rear, between any of the
three brands
You can have a stiffer front bar in relation to the front, but not a stiffer
rear.
So...
FRONT/REAR
Stock/stock OK
Stock/Daizen NOT OK
Stock/TRD NOT OK
Daizen/Daizen OK
Daizen/stock OK
Daizen/TRD NOT OK
TRD/any-rear OK
Any-front/no-rear-bar OK
Basically the non-ideal but acceptable combinations above will just have
more understeer than normal. The car will plow a little more, but the rear
will not try to come around. Completely safe though, just not all the great
handling.
Too much rear bar in relation to the front will make the rear try to come
around - this is a dangerous situation."
He said that it would of been okay to just drive my wifes car without any rear sway. According to his chart haveing Daizen Front and Stock Rear is okay. Well from trying that out myself Sunday I would not recommend that set up
Ivan
3dog
PHML
Suspension and Brakes
129
08-02-18 09:29 AM
