Silk Road springs...What spring rate???
So i'm about to order some custom silk road coilovers made for the supra but i'm gonna throw them on my sc4. When you order them you get to specify what spring rates you would like.....My question is for a daily driver that drifts on the side with the occasional street race what are your guys recommendations on spring rates? thanks in advance.
the sc spring rates for these are 12/8 or u can go get the supra spring rates 18/10. i went with the supra rates. and it's awesome! i wouldnt do mix/match custom rates cuz unless u really know what you're doing and you're familiar with the damper and valving of this particular coilover, it's probably a bad idea
if i had to do it all over again, i would have bought the silk roads in an 18/16
i currectly have the JIC FLT-A2 with 14/10 and it definately is not stiff enough for me, but i do a little more drifting then most people on the street.
i've run the flt a2's and even with a lower spring rate, the silk roads are way stiffer
On http://www.driftfactory.com/product_...oducts_id=2900 it says you can order custom spring rates, what do you guys think would be the best srping rate for a Drifter/ Daily Driver.....these ones are for the MKIV supra but they fit perfectley on my SC400 from what im told..
i orddered it from horsepowerfreaks.com for ~1730 ~ shipped to hawaii!!! he told me that was his last set on hand tho. i called munky works in hawaii and he told me he had to order it from japan and it would cost me 1850 shipped to hawaii and it probably take like a couple of months to get here.
