what factory rims will clear TT brakes
Only time will tell, so far so good, been driving for 5 weeks with no problems!!!
I'm thinking the TT brakes simply don't get as hot as the stock brakes, and the vented/crossdrilled rotors help a lot as well....
I suppose if I had the car on a track then the story could be different....
I have less than a dimes worth of clearance. Been that way for a year with no problems. There was absolutely no way I was going to use spacers. BTW, your ride looks good.
Thanks!!
Suspension is next along with new lower control arms, hopefully the car will stop riding like ___ once that's done (feel every bump in the road on stock setup rightnow)...
I was hesitant to spend money on spacers unless I really needed them!
There's a more likely scenerio of you hitting road debris or some other heavy object which could bend your wheel into the caliper, but again, that's unlikely as most bends occur at the barrel or the lip of rims, not to the face.
Here's a list of other oem Lexus wheels that will clear the TT/LS brakes for sure....
- 06/07 Split-Spoke IS250/350 Wheels
- 06/07 "ISP" Wheels
- 08 IS-F 19 Inch Multi-spoke wheels
- 06/07 "G-Spyder" Wheels
- 06/07 "Tourmaline" Wheels
- 06 GS300 Multispoke wheels
- 06/07 5-spoke GS series wheels
- 08 5-spoke GS series wheels(new design)
- 07+ GS450H Wheels
- 04/05/06 LS430 18 Inch 5-spoke wheels
- 04/05/06 LS430 17 Inch 6-spoke wheels
- 07+ 18 Inch LS460(L) multi-spoke "fan" wheels
- 07 19 Inch LS600HL 7-spoke wheels
- 07+ 19 Inch 5-spoke wheels
- 01-03 17 Inch LS340 wheels
- 95 thru 00 LS400 wheels
Other non-Lexus OEM wheels that would work...
- 93.5 thru 98 Supra TT(up to 2001 in Japan) Wheels
- 91 thru 96 Nissan 300ZX TT wheels
- 91+ Nissan Skyline wheels
- Late model Nissan 350Z Track wheels
- Late model Infinit G35 split 5-spoke wheels
- 07+ GS450H Wheels
