TRD Strut Bar fitment issues (holes not lining up)?
Old 10-25-06, 08:27 AM
mikevanle
mikevanle's Avatar
Default TRD Strut Bar fitment issues (holes not lining up)?
Just received my TRD stb today, and I'm trying to install it. However the holes are not lining up. They are well off.
Is there a trick or technique to installing it?
Old 10-25-06, 09:26 AM
rominl
exclusive matchup
rominl's Avatar
try to jack up one side of the car, or jack up the car from the middle. the idea is to flex the car a bit to fit.
Old 10-25-06, 09:35 AM
Neo
The One
Neo's Avatar
Yup. It is pretty well documented that there is a good chance you need to do this.
Old 10-25-06, 01:44 PM
mikevanle
mikevanle's Avatar
OK, I'll try that later then to see if it does anything. The person I bought this from said he didn't have any issues without jacking up the car or anything.
Old 10-25-06, 02:05 PM
mikevanle
mikevanle's Avatar
That seemed to have done the trick. Just needed the jack up the front end, then push down on the suspension so the bolts aren't poking through. Then put on the STB and then put the shocks back through the holes.
Btw - I thought the GS400 was supposed to have the greatest clearance? It barely clears. Maybe the thickness of a quarter? It'll prob even lower some more after driving. And this is with the stock spacer on.
Old 10-25-06, 11:33 PM
rominl
exclusive matchup
rominl's Avatar
the gs400 already has the "greatest" clearance, coz' the bar doesn't even fit on gs300 / 430
Old 10-26-06, 01:30 PM
upstateGS4
upstateGS4's Avatar
wow- thanks for bringing this to my attention... did you guys have better luck jacking the car up from the middle/front or one of the sides? i had just tried jacking up either side and it didnt help at all...
Old 10-26-06, 01:53 PM
mikevanle
mikevanle's Avatar
You need to jack up the car up in the front. Then remove the nuts on the shock towers. Then push down on the shock enough so the TRD bar will clear.
Old 10-31-06, 05:06 PM
3dog
3dog's Avatar
Default TRD tower bar
That is weird because on both my wifes car and mine.(both 99 gs400)
there was no need to jack the car up at all.
Bar go's on and off with ease.
I wonder if it is because we have 17" wheels?
I don't know if that makes any difference.
3dog
Ivan
Old 10-31-06, 05:53 PM
mikevanle
mikevanle's Avatar
Nah wheels doesn't make any difference. I guess it was just the way the shock bolts were angled. They come off and on the car pretty easy now, or easier.
Old 10-31-06, 09:06 PM
rominl
exclusive matchup
rominl's Avatar
3dog
Ivan
it's all about how the car has flexed over the yrs due to differnt driving, etc...
Finsun
10-13-18 08:23 PM
devin0986
IS - 1st Gen (2001-2005)
07-07-12 11:28 AM
ae80siq
02-19-11 12:18 AM
sputniknyc
Suspension and Brakes
05-16-05 08:12 AM
RanGer498
27
06-04-04 05:58 PM
Quick Reply: TRD Strut Bar fitment issues (holes not lining up)?
