Front wheels rubbing on fender
Old 10-29-06, 11:57 AM
icec0ld
icec0ld's Avatar
Default Front wheels rubbing on fender
Hi, I'm new to the club & I just got my SC about 2 weeks ago. I noticed that the front wheels rub the fender each time I pass a dip or any uneven surface. Also, it makes like a creaking sound (like an old spring bed) everytime it rubs.
My car came with lexus chrome rims but I don't think it's stock for an SC since I haven't seen it on any SC's yet. My tire size is 225/55/16. I'm thinking that I need new struts/shocks, but I just wanna make sure it's not somehting else.
I'd appreciate any advice on this. Thanks!
Old 10-29-06, 01:51 PM
Baoser
Baoser's Avatar
I have chrome wheels also and that is the stock tire size...probably a blown shock. Dunno... just taking a wild guess.
Old 10-29-06, 02:32 PM
icec0ld
icec0ld's Avatar
here's a pic of my wheels (without the center cap) just for reference. don't know if the same that u have.
anyway, yea it's probably the shock...
Old 10-30-06, 10:56 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Those are most definately NOT stock SC rims, or Lexus rims for that matter. But your tire size is stock. Blown spring and or shock.
Old 10-30-06, 12:45 PM
95 Integra
95 Integra's Avatar
Or the wheels are the wrong offsets.
Old 10-30-06, 04:56 PM
icec0ld
icec0ld's Avatar
I'm pretty sure it's not a stock SC rim, but the center cap says 'lexus' though. (don't know what the offsets are on this). has anyone seen this kind of rim from other models?
i'll probably try to change the struts & springs first and see how it goes.
here's a closer pic of the wheel
Old 10-31-06, 09:28 AM
lfrers
lfrers's Avatar
buy some cheap coilovers so you can adjust the height to your liking.
Old 10-31-06, 10:14 AM
95 Integra
95 Integra's Avatar
The offsets dont look to be that bad or bad enough to cause rubbing. They look like the old prime wheels that had fake "lexus" center caps to me. All the same, check out the fender/linear and see if you can tell where its rubbing....that might help determine why.
Old 11-01-06, 04:15 PM
bishoptane
bishoptane's Avatar
arent those the old school ls wheels if so there the wrong offset
Old 11-03-06, 12:36 AM
icec0ld
icec0ld's Avatar
i'm not exactly sure, but it would be interesting if someone could post a pic where that rim originated (well, if it's really from a lexus in the first place)
Old 11-03-06, 06:26 AM
sc250tt
sc250tt's Avatar
never saw those wheels on a lexus before .i think they are prime rims .your suspension is probably the culprit .as high as that car is it should not be rubbing like that .your shocks have to be dead
Old 11-03-06, 06:44 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
No. Those wheels are not Lexus rims....for any model.
Old 11-03-06, 07:45 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
you sure it's tire/wheel rubbing??? as high as it sits, I think you would be hard pressed to get the tire to touch the inner fender... are there clean marks anywhere, and if so, where at (clean means the tire is rubbing)
Old 11-03-06, 08:46 AM
cloudnine
cloudnine's Avatar
I would do the bounce test first before replacing the struts. The creaking sound is most likely from worn bushings or sway-bar end links.
Old 11-03-06, 11:04 AM
np20412
np20412's Avatar
can you elaborate on this bounce test regarding the shocks? My car makes a wicked creaking noise from the left rear, yet i don't bottom out anywhere on that wheel so I don't know if the shock is busted or if its a bushing or a control arm or what...what should I listen for or observe when doing this bounce test?
Quick Reply: Front wheels rubbing on fender
