Supra shocks
Banned scammer
hi guys i need some help. okay im thinking of getting the eibach prokit springs for the supra tt. I think it drops F1.3,R1.0. Now will i need supra tt shocks or can i use na shocks? R na shocks and tt shocks same? thanks in advance!!
No, n/a shocks will not work.
Any Supra TT springs require equivalent TT shocks.
All this is covered quite well in http://www.intellexual.net/faq.html#028 suspension area
Banned scammer
thanks..one more question. i been lookin at a website that sells eibach prokit springs. do i need the ones made for 96-98 supra tt to fit rite on those shocks?
Eibach ProKit for the Supra TT and shocks (either stock or aftermarket) for the Supra TT will work. Will drop your car about 1.5 to 1.75". You just can't use TT shocks with SC springs, or vice versa.
"OEM Supra shocks made for the Supra NA are slightly stiffer than OEM shocks made for the Supra TT. Note that the rear perch heights on both Supra NA and TT shocks are higher than the OEM Lexus SC shocks'. You are required to buy OEM or aftermarket springs designed for the JZA80/MKIV Supra when using these. OEM Lexus SC shocks, made by KYB, also function well with moderately lowered (1-1.5-inch) springs."
