Brake pads and rotors at 14.6k miles?
#46
It's absolute crap that they claim this is normal. The TT Supra has 315mm discs with exactly the same technology - four piston calipers, curved vanes, directional fitment, and with the OEM pads, we typically saw new brakes around 100k km (62,000 miles) on cars that weigh within 100kg (220 lbs) of each other on very similar tire sizes.
The things we didn't have on the Supra - EBFD and brake assist - I don't know about you guys, but it's taken me some time to get used to brakes that give me more than what I asked for on a regular basis. I learned threshold braking roadracing motorcycles where locking wheels has significant negative consequences, so I really DISlike a braking system that constantly second guesses me.
There is nothing in the repair manual that says the discs cannot be resurfaced. In fact:
All this talk about warping is quite contrary to what I know about brakes, and what Stoptech says about brakes. Discs don't warp. You may have uneven pad deposits making it feel warped, but the discs themselves don't warp. Carroll Smith seems to be of the same opinion, and he's forgotten more about high performance cars than the sum of us know.
Last but not least, price the brakes on an Evo or STI. $1000 in parts (discs and pads) for the front axle alone. It was one of the key decision makers for me when I considered these cars.
Parting shot - Brakes are for the timid.
If the runout exceeds the maximum value, change the installation positions of the disc and axle so that the runout will become minimal. If the runout exceeds the maximum even when the installation positions are changed, check the bearing play in the axial direction and the axle hub runout (See page AH-6). If the bearing play and the axle hub runout are normal and if the disc thickness is not within the specified range, grind the disc. If the disc thickness is less than the minimum, replace the disc.
#47
Like I mentioned before, it's probably a manufacturing/QC issues or the lug nuts were improperly torqued.
Either way, they shouldn't do that in at least this early.
#48
Agree, but you've got to heat up the pads and rotors fairly significantly to start getting those pad deposits.
also, all these talk about proper torquing the lugnuts. can someone tell me what the proper torque should be? i never knew that improper torquing would lead to these problems! thanks.
#50
Man, this is bullsh1t!
My 01 IS300 was driven like there was no tomorrow (i.e. I drove it very very aggressively) and did not have to replace the brakepads until 79000 miles! And this was for the rear pads! The front lasted another 8000 miles. If this is the service interval for the new IS for it's brakepads then it is very disappointing. 15k miles for a set of pads? Might as well have bought a sentra with the same sh1tty warped rotors and poor brakepad wear.
stevelifts
05-25-22 09:25 AM
