Swaybar endlinks loosening with Daizen swaybars?
Old 11-29-06, 09:26 AM
rwheelz
rwheelz's Avatar
Default Swaybar endlinks loosening with Daizen swaybars?
I installed the Daizen swaybars a while back (2-3 months). Great improvement in handling. However, I have noticed that the endlinks keep coming loose on the front (the 2 bolts that attach the swaybar to the endlink). Did other people loctite these on? I am using the specified torque for install.
Also, I thought my rear was holding fine, but I heard a clunk when I went through a big dip today, and when I looked at my rear bar the driver's side endlink was completely disconnected, I guess the nut fell off. To make matters worse, this endlink is bent now as well (I am not blaming the Daizen sways for bending the endlink, I think it bent because it became half loose).
Are other people having this problem? Using loctite? I don't want to loctite the rear because I may want to adjust it later.
Old 11-29-06, 09:52 AM
rominl
exclusive matchup
rominl's Avatar
did you use loctite? i can't remember where but i remember some place you need to use loctite
i haven't had any issues on mine for yrs
Old 11-29-06, 10:09 AM
GSteg
GSteg's Avatar
daizen recommends using loctite in their instruction.
Did you use a hex tool to tighten the nut?
Old 11-29-06, 10:32 AM
eman88
eman88's Avatar
Yup.....use loctite on all my bolts...waited a few hundred miles and did re-tight on all the bolts to makes everthing is good.
Old 11-30-06, 12:03 PM
TeeLex
TeeLex's Avatar
Yes, definitely use Loctite on the nuts and bolts. I believe the Daizens' end flats are thicker than the OEM sways and this does not allow as many threads to be engaged when tightening the nuts/bolts.
Old 11-30-06, 12:49 PM
PHML
Master Thread Closer!!
PHML's Avatar
Yep...loctite it....even the rears....its easy to re-adjust the rear endlinks even with loctite.....loctite is NOT like superglue.
pete
Old 11-30-06, 03:44 PM
rwheelz
rwheelz's Avatar
thanks guys! I need to order at least one new rear endlink though
damon
Suspension and Brakes
12-12-08 08:15 AM
Red Bully
09-06-08 04:42 PM
Scott1258
12-10-07 10:25 AM
Grover
03-02-06 06:14 AM
RA40
12
11-09-04 04:19 PM
Quick Reply: Swaybar endlinks loosening with Daizen swaybars?
