i suck at the search! camber bolt options????
ok, i cant seem to find the thread i know exists, but im looking for info on the camber adj. bolt. i read somewhere that you can get an extra degree or two from using camber bolts from another lexus... i believe it was the LS400, but i cant remember. if anyone knows what im talking about and would like to clarify, i would greatly appreciate it. thanks in advance.
i want as little wear as possible. my car is lowered with eibachs, and im not sure if i will have enough adjustment to take out the camber and preserve my tires.
Maintenance Moderator
http://www.mkiv.com/techarticles/lan...ent/index.html
is what I would recommend if you want decent performance and good tire wear...
ive seen those specs, but i think that the max you can get out of the front camber bolts are -1degree. i was just wondering if there was a way to get back to zero degrees camber. i thought there was another bolt available from lexus to take care of this...?
I have some pretty aggressive alignment settings, and although my tires wear quicker than normal, it's still not horrible... I don't remember 100%, but I think when I was checking out adjustments on my car, I could get it to -.5 degree no problem, which is well within factory spec...
