Odd handling after front end alignment
My 99 GS400 has become kinda twitchy after the DAIZEN bushing installation and subsequent front end alignment. It definitely has not done this ever before, even through two sets of tires.
I'll try to post the current alignment spec sheet below, but what it feels like it is doing is following every road irregularity. It makes it kind of "darty" or "twitchy". Hopefully that makes some sense. It's at it' *worst* when changing lanes. Toe in/out ajustment perhaps?
It can do it while driving straight down a road also, it just seems to depend upon road conditions. There are a RARE few roads where it doesn't exhibit the problem, but most roads around here have typical mid-west, high traffic issues.
The weird thing is that I did NOT have these issues on the same tires just before the bushing swap. Too bad I don't know what the alignment was at beforehand either!
Any idea's?? It's driving me NUTS!
(oh yeah, the 'before' stats on the paper are out of whack because it's immediately after swapping bushings, balljoints, and tie rod ends)
Sometimes, yes. (Both Left and Right) I must say that I am fairly familiar with the basics of Toe, Camber, Caster, etc and a little on how it affects my driving, but, I've just never felt this before. <shrug>
I'm not constantly fighting the wheel, but, if there is a road irregularity, then yeah, I'm probably making minor steering adjustments,....even when going in a straight line.
PS. Document looks better up above now!
A tire breakdown and rotation with balancing will likely cure Most of it and...time!
Good luck~
https://www.clublexus.com/forums/sho...d.php?t=221624
G
UPDATE:
Sorry for the holiday delay!
I rotated the tires front to back and still exhibited similar problems.
As I had mentioned (I think), I needed new tires anyway so I went ahead and got those before the holiday traveling and LOW AND BEHOLD my problem seems fixed!!!
I'm shocked. Never would I have guessed that this was the *only* problem, but, the ol Lex performed very well for over 250 miles this past weekend.
All 4 old tires did exhibit visual camber wear for what it is worth.
I also got the Hunter 9700 (?) Road Force balance for these old 17" steel wheels. This is the first time the car has had NO vibration since I bought it 3 years ago. (through 2.5 sets of tires and now, finally, the new bushings)
All the planets are finally aligned and the car rides like it should!!! Too bad it took 3 years to get here!
I just got a alignment too and have noticed my car drifting to the right.
They said I need a new inner tie end soon.
I got my tires balanced and mounted and then had the alignment done all at Sears.
Did my tires go out of wack and need to get new ones?
Or can the bad inner tie end cause the car to drift right?
Hmm..................
