SC300 Cross Floor stabilizing Bar
Old 12-19-06, 09:44 PM
$C300
$C300's Avatar
Default SC300 Cross Floor stabilizing Bar
Is it worth it?
Old 12-19-06, 09:52 PM
Boostshakalaka
Boostshakalaka's Avatar
do luck makes one specially for the sc
Old 12-19-06, 10:06 PM
D1GP
D1GP's Avatar
what does it do? does it really help with handling?
Old 12-19-06, 10:09 PM
$C300
$C300's Avatar
I believe that is for the sc, but is it worth it?
Old 12-20-06, 12:43 AM
Boostshakalaka
i'm pretty sure the one u posted is a universal one, our trans tunnel is way higher. my friend had one on a sti, he said it made a noticeable difference, the car doesnt understeer anymore, it actually oversteers every now and then. kinda cool cuz its an awd. i have another friend that has the do luck one in his hachi and says it is noticeable. i doubt the universal one you posted is any good, save up and buy do luck rear cross bar
Old 12-20-06, 12:44 AM
Boostshakalaka
also, i believe this goes in the suspension/brakes forum
Old 12-20-06, 08:37 AM
scoarer
scoarer's Avatar
although it may state that its for the sc300, it is definately a universal one, they just lenghten the tubes depending on the make..Fitment is horrible, we put it in my buddies 180sx and had to use god knows how many washers to fit it. Also that humugo bracket on the ends most likely have to be cut/trimmed to fit..But overall, it did improve handling and stiffening of the chassis if thats what you want.
Old 12-20-06, 08:50 AM
96gti2.0t
96gti2.0t's Avatar
do you have to drill into the car to mount this? how does it mount?
Old 12-20-06, 09:50 AM
vipsoarer
vipsoarer's Avatar
Im going to say that if it does anything to our chassis that it will be minimal. The rear tub of the sc is extremely strong and, like a rear strut brace, wont do much to the flex of the body. What are you trying to achieve by adding this? Its not going to help you turn nor is the body of the car known for excessive flex. I think your money is better spent elsewhere.
Old 12-20-06, 01:11 PM
Sc dRifta
*****Do not buy from this member until further notice *****
Sc dRifta's Avatar
agree if you remove the rear seats on your sc and lift up the carpet there is a factory brace already there id spend that money on Stabilizer Bars Preferably TRD ones that is money well spent. if you are really worried that much about body rigidity then do what i did go buy a mig welder and spot weld all the seams 1 1/2" apart that will help . btw to have a shop do this its like 45 cents a weld and i had over 600 welds done.
Old 12-20-06, 11:36 PM
$C300
$C300's Avatar
BTW dose anyone know who has a Tanabe strut bar in stock ( the red one)?
Old 12-20-06, 11:52 PM
stevechumo
stevechumo's Avatar
For regular driving, heavy street racing, or even mild dragging, this cross bar isn't needed in any ways. It might be good for drifting, which requires a lot of hard leaning and cornering. Other than that, I don't think it's worth anything. It makes the interior more ugly, and not so cool. There could be some really cool stuffs to decorate for the interiors such as the custom seats, dash board, stereo, steering wheel...etc.
And if you want to show your car is a powerful car, then add a turbo system and put some gauges on the dash. However, if you want to really strenghten the car body against flexing, without making it obviously ugly, sorry for my word, then ugrading to bushings, strut bars and swaybars will do the job just fine. There're some available front hi-performance strut bars and swaybars already. You can still have the custom rear strut bar and swaybar made.
Old 12-22-06, 09:47 AM
Boostshakalaka
speak for yourself, i think a bunch of bars on the inside of the car is sexy as hell
Old 12-22-06, 02:48 PM
AME_VIP
AME_VIP's Avatar
If you ever driven your car without a cage and then with a cage, you will know its a night and day difference. This kind of stiffening of the chassis can only help.
Old 12-22-06, 02:59 PM
SUPRMSC
SUPRMSC's Avatar
A bunch of bars that marginally do nothing but add more weight to an already heavy car
Quick Reply: SC300 Cross Floor stabilizing Bar
