Lower Ball joints
Old 08-17-07, 03:28 PM
  #151
UZ214
UZ214's Avatar
i just ordered the ball joints sewell lexus, around 130$ what else i need to get? i have 90k miles on my gs400, 2000 ..dont have any issues but after reading all this i am scared
Old 08-17-07, 11:33 PM
  #152
LiLS
LiLS's Avatar
so what about the upper ball joints?
also what needs to be replaced all at once, lower ball joints and what esle
Old 08-18-07, 02:35 AM
  #153
//935GS400
//935GS400's Avatar
Originally Posted by dqb3000
i've noticed from reading the entire thread, that this only happens to gs400's. i have a 99 gs3 and i think i might have this problem too. when i'm driving slow or driving in traffic, i notice the driver's side chirps when i tilt the steering wheel to the left...does this mean that my ball joints is going out too? sometimes i hear it when going straight...what i don't understand is how does the ball joint make noises when the wheel is spinning? but while its chirping i just tap the brakes and the sound it gone? it makes that sound like the brakes are out but i checked it out and its fine! someone please explain all this to me, thank you!!!
same problem. is this a ball joint problem?
Old 08-18-07, 08:45 AM
  #154
johnee78
johnee78's Avatar
Exclamation
I would replace ball joints on any GS that has over 80-90k miles and while your there you should also replace the tie-rod ends..
Old 10-10-07, 06:37 PM
  #155
drewefx
drewefx's Avatar
Hi all, i just had my 98 gs3 drop on me cause of that stupid balljoint. Is there a certain type of ball joint and tie rod end that i should change like what are the best ones out there? please advise and thanks
Old 10-11-07, 04:11 PM
  #156
BobaDrift
BobaDrift's Avatar
Okay I just hit over 100k miles on my 99 GS300. No noises but ordering the items anyway. Hit up Sewell and they don't have the item it seems. Or at least it shows a price of 0.00.
So where else has everyone ordered their stuff?
Old 10-11-07, 04:43 PM
  #157
GSteg
GSteg's Avatar
Give them a call. Looks like they're renovating their website so not everything is updated.
Old 10-11-07, 08:58 PM
  #158
bigmemory
bigmemory's Avatar
I had Lexus do the "Certified" inspection on my 2000 GS300 ( which has 168k miles). The only major thing that turned up was "weak" balljoints.
Old 10-12-07, 07:31 AM
  #159
Billh2
Billh2's Avatar
Had my car in yesterday for an oil change and an H-Brace installation. Had my tech check the ball joints. No problem found.
Old 10-18-07, 10:44 PM
  #160
BobaDrift
BobaDrift's Avatar
Well Sewell's site works again. Seems as though you can't get them for what everyone did before. And yes that includes the CL code.
I'll be changing my lower ball joints this weekend. Not because I need to, but just for peace of mind.
Old 10-21-07, 12:53 PM
  #161
lexi4darin
lexi4darin's Avatar
I just did.
I recommend tie rod ends and ball joints at the same time. That's what I did and the car is driving sooo nicely.
The piece of mind would have made this swap worth it but the car rides a lot nicer too.
Old 10-22-07, 01:53 PM
  #162
jonathancl
jonathancl's Avatar
I just did my lower ball joints because the parts weren't very expensive.
I did notice a ride improvement, but it was very slight. I got more from a road force balance and a tech who took the extra time to match the tires and wheels as best he could.
Old 10-23-07, 11:50 AM
  #163
Benjamin T
Benjamin T's Avatar
my order from sewell:
Product #:43330-39455, Lexus OEM Lower Ball Joint Assy Front Rh, Quantity:1, Price:$75.36, Item Total:$75.36
Product #:43340-39345, Lexus OEM Lower Ball Joint Assy Front Lh, Quantity:1, Price:$75.36, Item Total:$75.36
Product #:45460-59015, Lexus OEM Tie Rod Assy Rh, Quantity:1, Price:$46.34, Item Total:$46.34
Product #:45470-59015, Lexus OEM Tie Rod Assy Lh, Quantity:1, Price:$62.69, Item Total:$62.69
why is the LH tie rod assy more expensive thant the RH side?
Old 10-25-07, 03:25 PM
  #164
PushinLEX
PushinLEX's Avatar
http://www.tmengineering.net/suspens...n/make/gs.html
TM Engineering can beat this price. They also have all the brushings you need. Just order everything at once. I believe the steering rack brushings are on backorder though. I'ma bout to do a complete suspension overhaul through them so i'll call to confirm.
Old 10-25-07, 06:37 PM
  #165
jesse gs30
jesse gs30's Avatar
Default aboutr your ball joints
hey my name is jesse just had a quick question my ball joint just went out on my car and i was wonder ing where you got yours from are they after market? or did u get them from a dealer?
get at me a.s.a.p. please!!!
-jesse
Originally Posted by rgarjr
Just received my new balljoints...
Quick Reply: Lower Ball joints
