Lower Ball joints
#46
You know..the other day when I was under my car to check for that loosness, I found that the guy who did my alignment didn't tighten my passenger side tie-rod nut!
I tighted it up and it seem to be better, but there is still play. Right now, I'm pointing fingers to the wheel bearing or the inner tie rod (outter tie rod is fine) for the steering rack. The I heard the wheel bearing is a pain in the butt to install though.
#47
hey guys. i have a 98 gs 400 and my ball joints just went out on me. i have 109k on my vehicle. it was pretty scary. just the day before i came back from LA driving on highway 5 at about 90 mph. luckily i was driving down my mom's street with my wife at 30 mph when it happened. now my car is in the body shop with a shifted hood and a bent out fender. you know your ball joints are bad when you start hearing clicking noises when you break or turn. also when you drive and make a turn and your wheel doesnt come back. that means your ball joints are about to go out in the next 5 min. "JUST GET THEM FIXED"
Brian
Brian
#48
Good teaching
I have to replace the same on my GS 400 (125k) (Lower ball joints)
Where did you bought them & how much?
Where is the best store to buy Lexus parts?
I'm already new in this matters...
Thanks
Thanks
#49
buy it at sewell lexus (lexus-parts.com)
Use coupon code CL911M to receive 10% discount.
Should end up around $120 shipped
http://lexus-parts.com/partdetail.as...CategoryID=113
#50
"CHANGE THEM A S A P ! ! ! My 99'GS400 just collapsed on me doing 25mph. Its not pretty. Ended up getting front wheel alignment, tie rods new ball joints, wheel speed sensor, ABS cable and a wheel hub. All this at 112,000 miles on it. Everything str8 though. Just happened on last thursday and back rollin, just rollin with $1600 less
Richmond, Va roads are a b***h!
#51
#52
I agree that Lexus should do something, but let's face it, they probably won't, particularly because these cars are 7-9 years old with 75k-125k miles. As they say, an ounce of prevention is worth a pound of cure.
I can't speak for the 01+ GS's because I've heard they have redesigned ball joints, but if you're driving a 98-00 GS with 75k+ miles, just change them. Just change them. The parts cost around $125 and you can have a local shop install them for probably around $100 (or pay Lexus a bit more to do it). I changed them on my 98 GS4 at 60k and on my 99 GS4 at 80k. It's really a no brainer.
#53
Just replaced mine at 102K, the steering started to get loose and i was not going to put anymore money into this thing maintance wise than i have to rather spend it on the performance parts or a new set of wheels.
#54
Just got back from tire shop...new lower ball joints, tie-rod bushings, and Bridgestone RE960s. Have 114k miles. Mechanic said original balljoints were OK, meaning not completely worn. I believe that due to the mostly freeway miles driven, the balljoints weren't as worn as others.
Now let's hope my alignment issues improve now!
#59
Sorry to bring this back from the dead, but 'um ... Anyone know someone in the Atlanta area that can do these? Dealer quoted $412.00. Please contact me doingdamage@gmail.com.
#60
Greetings,
Just returned from pick up one scared wife with a real sorry looking 98Lexus...she was driving down the road today and the driver's front wheel came off at a 90 degree angle...stuck in the wheel well sideways and did considerable body damage to the front fender. She is still really shook up from the experience...so I've been searching the net and found that Lexus has a recall (NHTSA Number 99V125000) which states, "Passenger Vehicles due to inadequate lubrication of the inside of the lower ball joints. Excessive wear can occur causing damage to the lower ball joints, separation of the lower ball joints from the steering knuckle arms could occur. Consequences: This condition could lead to a loss of control of the vehicle, increasing the risk of a crash." No ****!
I've never dealt with a recall situation. My questions are: What are the chances of the dealership paying for the repair? Assuming the answer is yes, the only Lexus dealer is 90 miles away, will Lexus pay for the towing, or will they allow the local Toyota Dealership to do the work? Will they consider fixing the resulting body damage too, or just put on new steering parts, smile and hand me the key?
Thanks,
John B.
Topeka
Post Script: Tomorrow I'm going to take photos if anyone is interested...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Thanks,
John B.
Topeka
