Brake Lines Question
Anyone who can help me with this one, it'd be greatly appreciated.
I had Rod Millen Stainless Steel brake lines installed on my '99 GS 400 recently from a reputable mechanic shop (maybe an oxymoron). Soon afterward, I've been experiencing a loud scratching sound coming from underneath my car when turning the wheel all the way to the right.
I took the car in to Lexus of New Orleans and they told me that the Rod Millen Stainless Steel brake lines are simply "too long" and the noise I'm hearing is them brushing up against the wheel once I turn all the way to the right.
The logic of this argument makes sense to me, however would RMM not have the hindsight to see that this problem would occur? Or is there maybe something else behind it, such as the installation job?
I'm considering switching back to the factory brake lines as I really haven't felt any difference with the stainless steel ones anyhow.
Any help or insight will help. Thanks,
sTWO,
Is there anyway for you to shorten these lines?
Do you have a picture of the brake lines?
By the way fellow Club Lexus addicts, what is so special about these brakes lines?
If anyone can provide a pressure/ temperature specification along with type of end fitting (and length), I'm sure i can get people that are interested a very good price on probably the exact same part. People that sell these probably make a nice little profit on these "LEXUS" brake lines and they are probably a standard item which I can easily get my hands on thru my job as an engineer.
GS4fun,
To my knowledge they cannot be shortened. Below is the link for a picture of the brake lines:
http://www.rodmillenstore.com/is_300/lines.htm
It says is_300 , but they are designed for the GS series. I even confirmed this from a few different sales people @ RMM.
If I decide to change them back to the factory ones, Lexus will provide the part free of charge, so that's not my main concern. Although I'd like to figure out a way to keep these stainless steel brake lines while solving the scratching problem.
Thanks,
Thanks,
By twisting the flexible pipe you can shorten the end-end length. If you twist it too much, it might kink and that would be bad.
Salim
Salim
I read somewhere that you really don't need SS brake lines and i read in grassroots magazine that SS is not really needed unless you race on track when you constantly using the brakes. I heard that it's actually worse overall if you use stainless steel brakes under normal driving conditions. Just check out last months edition of Grass Roots where you can learn a lot about car parts.
Thanks for the replies everyone.
I think I have a good idea of what I need to do now. It's a toss-up between removing the SS brake lines and putting the factory ones back in or twisting the flexible pipe to shorten the length. Either way the problem should be solved.
Thanks again,
Thanks again,
Originally posted by GS4fun
sTWO,
sTWO,
On my 98' Cherokee I have 28" Front SS Brakelines. They are long for daily driving, but when I go Off-road they are the perfect length. What I did to solve my problem of them being to long is. Go to Pep Boys or Auto Zoned and get a Throttle Spring. Pep Boys has a big selection. I hooked one looped end around the brakeline and one end in my fender. It holds the Brakeline there and if I need the length it will stretch with no problem. Easy Fix, cost me about 3.25 or so.
I don't know if you can see the spring in this pic, but here goes.
EDIT***********************************
Why Does my Pic not Post? Only Shows a URL?
I have a 94' GS300 with Rod Millen front brakes and I have a leak in one of my stainless steel lines, can you help me out, will they fit my car, cost? I only need one for the front left, I really don't want to have to buy an entire kit. Do I have to replace the line with the same as what the kit came with, or can I use any stainless lines?
It's all about the way in which you install the lines. One of my lines was rubbing when the wheel was all the way turned left (left side). I simply re-positioned the lines further away from the tire and all's fixed!
