Damnit, another thing needs to be replaced.
So did you have to get new balljoints? Or was it something else?
As for all these GS's with balljoints failing around the 100-120K mark...I'm surprised lexus hasn't been sued or something. I mean on most other cars if the ball joint goes out, the car is still supported and somewhat in the air. As for the GS, the whole car slams to the ground. It's probably due to the suspension design that causes the car to hit the ground. Does lexus have some kind of TSB, notice, or recall? Or at least something saying that the ball joints MUST be replaced and making it serious enough so the customer doesn't think the dealer is just trying to make a quick buck off extra services. Maybe the suspension on the GS isn't very stout? I know of several camry's going 200-300K miles still running the original suspension pieces(besides shocks). What about people who bought the car used and don't goto a lexus dealer for service. They won't know about the dangers. I think they need to make a bigger deal out of this issue because a failing balljoint a highway speeds is very very dangerous. I think this is big enough of an issue to possibly warrant a recall. Maybe not a full recall, but just sending a serious notice to all GS owners (TSB saying do it or else...lol).
Anyways, I'm probably just ranting here...but what do you guys think about it?
As for the balljoint issue I think it is so stupid that they designed the GS so that if this one piece fails it will destroy important expensive suspension pieces from the weight of the car falling on it and it will likely cause a serious accident. If you are going design something like that at least have the common sense to build the ball joint strong enough to last the life of the car.
I have this issue with timing belts too where with many engines if the timing belt fails the engine will be destroyed with pistons and other pieces colliding with each other but other engines like non-interference engines are safe if the timing belt fails. After all these years of knowing this problem why would you still keep designing and making engines that will be destroyed if the timing belt breaks? If you are going to keep designing engines this way because of simplicity or costs then at least make a timing belt that is strong enough to last the life of the car instead it needing to be replaced 90K miles and possibly failing before it is changed leading to destruction of the engine because it was not designed with enough strength.
Kinda off topic, but just replying to what you said about the timing belt and interference engines. Most modern high performance/ultra high performance engines are very high compression compared to what they were back in the day. The piston goes much further up the cylinder to extract more power. I'm sure as engines get more and more advanced and also more powerful they will all become interference setups. The good news is that Toyota is using timing chains rather than belts on the new engines. Although it won't last the life of the car, it's a heck of a lot longer than a timing belt.
ball joints will go on anycar in nyc with the potholes we have here lols and the GS is a heavy car but its just a good thing for people to realize if they here any weird noise in the suspension tey should go check it out or get it checked out even mechanics can over look a ball joint sometimes if it doesnt have much play and is left on the spindle. Maintaince on any vehical shouldn't be rated by mileage but how you drive -=) if u have lead feet change ur oil buy 1500k or 3000k if ur runnin mobile one or somthing etc the guildance on mileage is just approx
i'm 100% sure there was a TSB for ball joint failure on first generation GS'. this was never addressed with 2nd gen GS'.
i guess lexus didn't learn from their first mistake
this is what i found
http://www.lexusforum.com/recalls-an...153/Recall.htm
1993 Lexus Gs300
NHTSA Campaign #: 95V072000
Manufacturer Campaign #:
Make: Lexus
Model: Gs300
Year: 1993
Component: Suspension:front:control arm:lower ball joint
Manufacturers Involved: Toyota motor co., ltd.
Begin Date Of Manufacturing: 09/01/1992
End Date Of Manufacturing: 05/01/1994
Recall Type: V
Potential Number Of Units Affected: 27604
Date Owner Notified By Manufacturer: 04/28/1995
Recall Initiator: Mfr
Manufacturer Responsible For Recall: Toyota motor north america, inc.
Date Report Received By ODI: 04/03/1995
Date Added To File: 04/14/1995
Regulation Part #:
Federal Motor Vehicle Safety Standard #:
Defect Summary: The spherical portions of certain lower ball joints had finished surfaces that were not smooth causing friction with the surface of the ball joint cap.
Consequence Summary: This condition can lead to separation of the balljoint increasing the potential for a vehicle accident.
Corrective Action: Dealers will replace the lower ball joints on the affected vehicles.
more reading:
for 2nd gen they only offered a TSB for checking for excessive play.
here is the link:
http://techdoc.lexus-europe.com/tsb_...asp?fileID=639
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
1993 Lexus Gs300
Make: Lexus
Model: Gs300
Year: 1993
Recall Type: V
Regulation Part #:
more reading:
here is the link:
