OEM or aftermarket part?
So i was changing my lower ball joints, and i busted my right outer tie-rod boot. Should i just order a set of tie-rods from sewell lexus (lexus-parts.com) or i should just buy a right one from autozone? keep in mind that the sewell lexus parts are all oem, while places like autozone have a 3rd party manufacturer.
so yeah, despite the guide on DIY lower ball joint, i went out and rented a fork tie-rod separator (after the guy convinced me that it will work), but it poked my tie-rod boot clean, and couldn't even fit itself in the boot! Under frustration, i went to autozone and asked for the pulling kind, and nevertheless, the boots came off, and i did the whole swap within 15 mins on the left side.
Cliff notes:
When there's a guide, follow exactly what it says; do not make any substitution unless you know what you are doing.
You'll need to get the steering rack bushing kit from sewel lexus. It should run around $40 shipped or so. use coupon code CL911M during checkout.
It's an easy install. If you can do the balljoint, then you'll have no problem doing this. There is a DIY thread floating somewhere in this forum.
aneidiaz
Suspension and Brakes
23
01-08-14 01:41 AM
Och
14
07-30-08 10:23 PM
kenkaniff
33
04-20-08 10:48 PM
