Looking to purchase Eibach Pro-Kit and KYB AGX set-up
Old 03-23-07, 01:11 PM
hass
hass's Avatar
Originally Posted by Blk97SC300
It's an OK drop.
The front sits nicely, but the rear isn't low enough.
Allen
I agree with Mr. Allen, the rear does sit a little bit higher but it doesn't annoy me that much lol.
-hass
Old 03-24-07, 02:22 AM
9teens
Banned SCAMMER
9teens's Avatar
the rear is supose to be higher,to give the raked look.
Old 03-25-07, 12:13 PM
dinhnerz
dinhnerz's Avatar
anyone knows where I can get a good deal on this setup?
Old 03-25-07, 12:29 PM
hass
hass's Avatar
I purchased it on here.
-hass
Old 03-25-07, 12:38 PM
dinhnerz
dinhnerz's Avatar
how much did it get it for? from whom?
Old 03-25-07, 03:23 PM
hass
hass's Avatar
From a member used for little amount of time, 350 shipped i think
-hass
Old 05-07-07, 02:19 PM
Hil
Hil's Avatar
dont mean to thread jack.. but i plan on getting the same set up... and i was wondering if those of you guys who had the setup had any issues getting the car aligned or any camber issues + tire wear
Old 05-07-07, 05:46 PM
Khaos
Khaos's Avatar
I have the Supra TT Eibach/Bilstein combo. After I installed the springs, I took it to a shop to get it aligned. You'll need a camber kit from TM Engineering (http://www.tmengineering.net/suspens...zen/index.html)
The front sits a little lower than the rear.
Old 05-10-07, 12:31 PM
Hil
Hil's Avatar
looks great
so i need both front and rear camber kits? or just the front
Old 05-10-07, 01:54 PM
Khaos
Khaos's Avatar
Originally Posted by SCboy
looks great
Thanks. I had both the front and rear camber kits installed. You might be able to get away with only installing the front camber kit.
Old 05-10-07, 02:07 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Um, I still don't see why you guys are needing camber kits???
there is a TON of adjustability on the SC's from the factory - enough that I can go from -.5 to -3.0 on the front with the stock adjusters...
same with the rear, except I can get about -3.5
My car is lowered 1.8ish... (see sig pic)
Old 05-10-07, 02:51 PM
Khaos
Khaos's Avatar
I measured the before/after ride height of my car. The Supra TT Eibachs/Bilstein combo dropped the front of MY car 2.5" and the rear 1.0". The drop can vary slightly from car to car, but I could definetely tell (visually) that my front needed a camber kit because it looked like this: /--\
I first asked the alignment shop to align my car without the camber kit, but they said my alignment was way outta wack. They installed the camber kit and they were finally able to get the car aligned.
If you can get the camber corrected without a camber kit, then great! If not, then you know what to do...
Old 05-10-07, 03:11 PM
mitsuguy
mitsuguy's Avatar
My car looks like that all the way around - I run -2.6 rear, -2.0 front camber... But there is more than enough adjustment in the stock bushings to get you back to spec, or even more aggressive...
on supra shocks and Tein springs...
ric4044
SC- 1st Gen (1992-2000)
13
02-01-11 05:47 PM
Bender25
SC400 / 300 Classifieds
01-13-11 01:51 PM
sc400.ru
Suspension and Brakes
04-16-09 09:22 AM
sourcemine
03-20-06 07:17 AM
fredzdesig
03-13-05 11:33 AM
Quick Reply: Looking to purchase Eibach Pro-Kit and KYB AGX set-up
