Looking to purchase Eibach Pro-Kit and KYB AGX set-up
Hi Everyone,
I looked over intellexual.net's faq and did several searches regarding the Eibach Pro-kit (TT) and KYB AGX (TT) suspension set up.
I found lots of praise on its perfect drop, lessened roll and increased stiffness. What I couldn't find was a place to purchase these for a good price.
I followed intellexual.net's recommendation and visited TM Engineering, but I wonder if there were any other great sources?
Lastly, to just clarify. I own a black 93 sc300 and with all the documentation it seems the suspension setup I mentioned above would simply bolt in. Should I have any other concerns with the installation of this setup?
I also have this horrid screech (front) whenever I go over a speed bump, which I believe to be rotten bushings. Should I have the bushings installed with the suspension?
Thank You,
Thank You,
id go to supra forums and check it their fs section or just go to the sale section here. or tmengineering or ebay or luxurymods, just google ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
anyways i bought mine used at SF for 250 and no complaints here.
errr nm tmengineering, i read ur post again.
I purchased my set up on here for 325 shipped used. Check out supraforums and ebay. Since it was used and ready to drop in with the top piece, it was an easy install. Good luck, i like the TT Eibach/kyb agx since it's more of a drop than the SC eibach/kyb agx
-hass
-hass
How much of a drop is it? Just keeping my option open.
I'm looking for a stance, lower in the front and a lil low in the back.
I was planning to get adjustable megan coilovers.
hass,
Hows the ride on those shocks?
Hows the cornering? How is the body roll?
Could you post a picture of the side view of your SC?
Also how big are your rims?
Edit:
One more question, I read on the forum
that you could use KYB shock and eibach spring for sc300 for the front
and supra tt for the rear?
Or would you just recommend supra tt for both?
Edit:
hass,
Edit:
Edit:
![](http://www.imagestation.com/picture/sraid225/p4aa41dfdc5613aca913f407a7dafc6df/ea4fb918.jpg.orig.jpg)
-hass
It's an OK drop.
The front sits nicely, but the rear isn't low enough. With this suspension combo, the rear needs to be dropped a bit more- especially to even out with the front.
I got annoyed with the a$s sitting too high, so I just bought a set of fully adjustable coilovers
Allen
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Allen
