On with the TT brakes, Roll the fenders, 20's are here.
#33
I Vadim from Russia to the Urals go two years at Lexus SC 300 -97 years production from 2JZ-GE engines. This car I bought in Texas (Dallas).
I am a member of Club: https://www.clublexus.com/ and read topics that Americans are hot swap its Lexus SC 300 standard engines 1JZ-GTE twin-turbo or standard engines 2JZ-GTE twin-turbo with VVT-i.
I also wrote Club theme: https://www.clublexus.com/forums/lighting-128/.
I failed English, I hope that you will forgive me.
I have read in your club theme: On with the TT brakes, the fenders Roll, 20's are here.
Where you report that found his Lexus SC 400 brakes of Touota Supra JZA80-RZ (turbo). You painted well Brake Front calipers and decorated its logo "Lexus" is a beautiful, I will do the same.
There Touota Supra JZA80-RZ (turbo) Brake Front and Rear better than the Lexus SC 300: http://planetsoarer.com/suprabrakesII/S upraBrakeUpgrade.htm.
I have already bought Brake Front and Rear calipers for JZA80 -RZ (turbo) (LHS caliper Front and Rear LHS caliper).
I would like to buy-Rotor Brake Front-Ø 324 mm. and Rear Brake Rotor - Ø 325 mm. with perforation and grooves for the Front and Rear LHS caliper for JZA80 -RZ (turbo).
You made pictures Brake Rotor Front with perforation and grooves along with the Front Brake calipers for JZA80 -RZ (turbo), and reported that Rotor Brake Front manufactured by "iROTORS '."
What is the diameter of your Rotor Brake Front with perforation and grooves and a thickness Rotor Brake?
How much do these two Brake Front Rotor company iROTORS ' with out postage ?
Together me how I can order the firm "iROTORS '" - Rotor Brake Front-Ø 324 mm. Rear Brake and Rotor - Ø 325 mm. with perforation and grooves for the Front and Rear LHS caliper LHS caliper for JZA80 -RZ (turbo)?
I look forward to your advice.
Sincerely, Vadim.
PS. Please answer me Emeyl: buena@mail.ru
#34
Location: Sideways on the Yellow Brick Road! < Thats KS!
ScottURnot - greetings.
I also wrote Club theme: https://www.clublexus.com/forums/forumdisplay.php?f=128.
Sincerely, Vadim.
Sincerely, Vadim.
